Hi all,
i am currently using a ESP8266 to log the roomtemperature with a DHT22.
I now want to switch to a bme280 and log also the Air Humidity.
i am using this code
local SSID = "XXXXX"
local SSID_PASSWORD = "XXXX"
local SIGNAL_MODE = wifi.PHYMODE_N
MQTT_CLIENT_ID = node.chipid()
MQTT_CLIENT_USER = "openhabian"
MQTT_CLIENT_PASSWORD = "openhabian"
MQTT_CLIENT_KEEPALIVE_TIME = 120
MQTT_BROKER = "192.168.0.132"
MQTT_BROKER_PORT = 1883
MQTT_TOPIC_IN = "esp8266_station123/in" -- commands
MQTT_TOPIC_OUT = "bme280_Wohnzimmer/out" -- send values
MQTT_TOPIC_OUT2 = "bme280_Wohnzimmer/out2"
MQTT_TOPIC_OUT3 = "bme280_Wohnzimmer/out3"
MQTT_BROKER_SECURE = 0
m = nil
sda, scl = 3, 4
i2c.setup(0, sda, scl, i2c.SLOW)
bme280.setup()
function wait_for_wifi_conn ( callback )
tmr.alarm (1, 1000, 1, function ( )
if wifi.sta.getip ( ) == nil then
print ("Waiting for Wifi connection")
else
tmr.stop (1)
print("\n====================================")
print ("ESP8266 mode is: " .. wifi.getmode ( ))
print ("The module MAC address is: " .. wifi.ap.getmac ( ))
print ("Config done, IP is " .. wifi.sta.getip ( ))
print("====================================")
callback()
end)
function mqtt_handler()
m = mqtt.Client(MQTT_CLIENT_ID, MQTT_CLIENT_KEEPALIVE_TIME, MQTT_CLIENT_USER, MQTT_CLIENT_PASSWORD)
-- on publish message receive event
m:on("message", function(client, topic, data)
print("Received:" .. topic .. ":" )
if data ~= nil then
--print(data)
if data == "req" then
sendValue()
end)
m:on("offline", function(m)
print ("\n\nDisconnected from broker")
print("Heap: ", node.heap())
end)
m:connect(MQTT_BROKER, MQTT_BROKER_PORT, MQTT_BROKER_SECURE, function(client)
print("connected")
client:subscribe(MQTT_TOPIC_IN, 0, function(client) print("subscribe success") end)
end,
function(client, reason)
print("failed reason: " .. reason)
end)
-- send all 30 sec
tmr.alarm (2, 10*1000, tmr.ALARM_AUTO, function ( )
sendValue()
end)
function sendValue()
-- do stuff
T, P, H, QNH = bme280.read(46)
print(T/100)
print(H/1000)
print(P/1000)
local temperature = T/100
local humi = H/1000
local preassure = P/1000
-- publish to broker on topic
m:publish(MQTT_TOPIC_OUT, temperature, 0, 0, function(client) print("sent value="..temperature) end)
m:publish(MQTT_TOPIC_OUT2, humi, 0, 0, function(client) print("sent value="..humi) end)
-- m:publish(MQTT_TOPIC_OUT3, preassure, 0, 0, function(client) print("sent value="..preassure) end)
-- Configure the ESP as a station (client)
wifi.setmode(wifi.STATION)
wifi.setphymode(SIGNAL_MODE)
wifi.sta.config {ssid=SSID, pwd=SSID_PASSWORD}
wifi.sta.autoconnect(1)
-- Hang out until we get a wifi connection before the httpd server is started.
wait_for_wifi_conn( mqtt_handler )
When i only send one value to the mqtt broker using
but when want to send two or more values to the broker i get this error message:
PANIC: unprotected error in call to Lua API (stdin:11: attempt to index global ‘m’ (a nil value))
ets Jan 8 2013,rst cause:2, boot mode:(3,6)
how can i send multiple parameters to the mqtt broker? Does anyone have a tutorial?
