Sendcommand(int) is undefined for the type number
Hello together,
im facing a strange issue and I cant understand it.
I have an Number item called “TodayTemperatureSet” which i like to send a command. In VS Code im getting an error in a rule telling me
The method sendCommand(int) is undefined for the type Number(org.eclipse.xtext.diagnostics.Diagnostic.Linking)
But I got a lot other items that are working fine with the same format.
Here is a comparison of 2 items
//not working:
Number:Temperature    TodayTemperatureSet         "Heutige Zieltemperatur [%d]"
//working:
Number:Temperature    Kitchen_Set_Heating          "Küche Soll  [%.1f °C]"                          <heating>        (gKitchenRadiator, eRadiatorKitchen, gRadiatorSet)                                     {channel="homematic:HmIP-eTRV-C:ccu:00119F299438C8:1#SET_POINT_TEMPERATURE", ga="thermostatTemperatureSetpoint"}
The commands within the rule:
//not working:
 TodayTemperatureSet.sendCommand(21)
//working:
Kitchen_Set_Heating.sendCommand(17)
When i trigger the rule I also get an error at the same line VS code showing me as problematic:
Script execution of rule with UID 'homematic-3' failed: 'sendCommand' is not a member of 'java.lang.Number'; line 72, column 37, length 35 in homematic
I hope someone got an idea.
You’ll need to show the rule with the problem.
I expect you’ve defined a variable of type Number with the same name as one of your Items.
Thank you very much, that was it!
I had an number variable that i forgot to delete.
