I created rules to switch light brighness and color at certain times using cron. The rules were executed, but no change in brightness and color. The log of the action :
2019-06-24 19:05:04.389 [ome.event.ItemCommandEvent] - Item ‘Ceiling_Bulb_Brightness’ received command 40
2019-06-24 19:05:04.400 [nt.ItemStatePredictedEvent] - Ceiling_Bulb_Brightness predicted to become 100
2019-06-24 19:05:05.399 [ome.event.ItemCommandEvent] - Item ‘Ceiling_Bulb_Color’ received command 50
2019-06-24 19:05:05.408 [nt.ItemStatePredictedEvent] - Ceiling_Bulb_Color predicted to become 100
It received command to set brightness to 40% but then predicted it to become 100%?
Just a thought since you did not provide your item config.
You send a dimmer value 0% to 100% to a Color channel which in most cases consists of 3 Values knows as RGB example 255,0,0 (something like that).
get’s called
responds. Is your config correct?
edit:
Also your topic name is very undescriptive.
Command is very generic, device is also very generic and “not working” more like unexpected behavior.
The predictions come from openHAB autoupdate feature.
This listens for commands to Items, and guesses what the effect might be on the Item state. Then it issues a state update.
Any real update later from a device will overwrite the state.
In recent OH versions, bindings are able to influence autoupdate (the binding knows more about any real device).
You can disable autoupdate for individual Items if you find its predictions unhelpful.
What autoupdate does NOT do, is have any influence on commands being sent to devices by bindings.
If your device is not responding, you are looking in the wrong place. Maybe thing/channel settings are where to look.
