Hey, i hope you guys can help me. I want my radiators to turn off, whenever my window opens. My windowsensors (switches, no contacts) are all in a group.
Number Temperature_RoomA
Number Temperature_RoomB
Number Temperature_RoomC
Number TemperatureWhenWindowOpen_RoomA
Number TemperatureWhenWindowOpen_RoomB
Number TemperatureWhenWindowOpen_RoomC
I want to do all this with only ONE rule. I would like to NOT use val or vars. (If its possible)
rule WindowRadiator
Member of gWindows changed to ON
("Temperature_" + triggeringItemName.split('_').get(1)).sendCommand(("TemperatureWhenWindowOpen_" + triggeringItemName.split('_').get(1)).state as DecimalType)
I tried different things like. toString or âas Textâ and stuff. Always getting errors like: âCould not cast TemperatureWhenWindowOpen_RoomA to voidâ or â.state is not a member of Stringâ and stuff like that.
logInfo(âTriggerâ, "Item is: " + triggeringItemName.split(â_â).get(1)) always give me the correct Room (RoomA, RoomB or RoomC)
In addition to rossko57: There is no implicit var named triggeringItemName in rules that are triggered by Member of.
To be honest, itâs a bit difficult:
triggeringItem â the actual Item which triggered the Member of
triggeringItemName â the name of the item which triggered the rule when using Item as trigger (as a String Object).
As all of your window contacts are already in a group, please consider to also put the other two types of items in additional groups:
rule "Window Radiator"
gTemperatures.members.filter[i|i.name.endsWith(triggeringItem.name.split("_").get(1))].
heaad.sendCommand(gTemperatureWhenWindowOpen.members.filter[j|j.name.endsWith(triggeringItem.name.split("_").get(1))].head.state as DecimalType)
or way more readable (with val)
val strRoom = triggeringItem.name.split("_").get(1)
val myTemperatureItem = gTemperatures.members.filter[i|i.name.endsWith(strRoom)].head
val myOldTemperature = gTemperatureWhenWindowOpen.members.filter[j|j.name.endsWith(strRoom)].head.state.toString
myTemperatureItem.sendCommand(myOldTemperature)
