I have a perle script which stores my solar data into a mysql database, and I would like to make that available to openhab, ie send items ( power/energy) to Openhab.
There a probably a few ways to do this but what is the best way of doing this?
ie can I call a API to do this or use a specific binding?
openHAB itself is able to use MySQL as a persistence Service, but no other option (e.g. to query freely some sort of database - would be a very handsome feature, though…)
So the first option would be to use the REST API of openHAB.
Please open Main UI → Administration → Developer Tools → API Explorer.
It’s the Items which you are looking for, so open items and see all options to manipulate an Item (and its status).
Go to PUT items/{itemname}/state and click Try it out.
Set an existing Itemname and set the status you want to send to the Item. Click Execute, and you will (hopefully) get the curl call to set the item state.
Best practice is, to create a unique token for access, this is to be found in Main UI → Username (left down corner) → Create API-Token.
Another option is to use some sort of binding, e.g. create a script to send the values in question as a mqtt topic payload, then you will be able to create a corresponding mqtt thing to receive those messages in openHAB. There are many other options, but I tend to find mqtt one of the easiest ways to be integrated in existing scripts. As I don’t know perl at all (well, at least the name is familiar…), I have no idea if mqtt is an easy one here
