I was looking for a way to send messages from Openhab to gotify. I came across this thread: Gotify Push Messaging [solved]
It worked so far, but I wanted to send a picture for a certain application. As described in the documentation: Message Extras · Gotify
I worked on this for a while until I got the whole thing to work, and this is the result:
val String gotify_server = "https://your-gotify.server/message?token=<your app token>>"
val String gotify_headers = "application/json"
rule "Send Image to Gotify"
Item Test changed from OFF to ON
// image-URL
val imageUrl = "https://gotify.net/img/logo.png" //a local image stored in html folder also should be possible
// message text
val messagetext = "some text"
// gotify-message-details
val gotifyMessage = "{ \"message\": \"" + messagetext + "\", \"extras\": {\"client::display\":{ \"contentType\": \"text/markdown\" }} }"
// send to gotify
val response = sendHttpPostRequest(gotify_server, gotify_headers, gotifyMessage)
// Log for debugging
logInfo("Gotify Response", response)
Since I didn’t get it right the first time either, I hope I can give you a little help.
You can find out how to set up Gotify in the gotify docs (I can´t post more than 2 links, so you have to search for it ):
Best regards!
