I am having troubles to combine AND and OR statements in a rule. My script works but it sends anOn or an Off command even when it is not necessary. In this case the command wifi ON command is sent even when the wifi is already ON. For whatever reason I struggle to find the right setup and mainly the brackets make me mad. Can anybody please give a suggestion how to do that?
var Timer Timer_Wifi_DG
rule "Wifi timer"
Item zwave_device_414e6662_node10_alarm_motion changed or
Item zwave_device_414e6662_node7_alarm_motion changed
if((zwave_device_414e6662_node10_alarm_motion.state==ON) ||
zwave_device_414e6662_node7_alarm_motion.state==ON)
if(Timer_Wifi_DG!==null) {
Timer_Wifi_DG.cancel
Timer_Wifi_DG = null
fboxWifi24.sendCommand(ON)
fboxWifi50.sendCommand(ON)
else if ((zwave_device_414e6662_node7_alarm_motion.state==OFF) || zwave_device_414e6662_node10_alarm_motion.state==OFF) {
Timer_Wifi_DG = createTimer(now.plusSeconds(5400)) [|
fboxWifi24.sendCommand(OFF)
fboxWifi50.sendCommand(OFF)
