I just can’t seem to get my mqtt lamp switch configuration right so I need some help here.
I have installed the following switch: https://www.sunricher.com/zigbee-ac-in-wall-switch-sr-zg9101sac-hp-switch.html
Pairing using zigbee2mqtt is working and Mosquitto shows the switch topic.
My switch configuration in openhab 3 is:
UID: mqtt:topic:543765dc0b:ce0e4d8e86
label: Deckenbeleuchtung
thingTypeUID: mqtt:topic
configuration:
payloadNotAvailable: offline
availabilityTopic: zigbee2mqtt/deckenlampe_flur/availability
payloadAvailable: online
bridgeUID: mqtt:broker:543765dc0b
channels:
- id: switch
channelTypeUID: mqtt:switch
label: lamp
description: ""
configuration:
commandTopic: zigbee2mqtt/deckenlampe_flur/set
retained: false
qos: 1
stateTopic: zigbee2mqtt/deckenlampe_flur/state
When I click the switch in openhab, the state changes and the switch is working but 2 problems still persist:
When clicking the switch in openhab, not only the state of the root JSON path changes but a second
set
topic appears. -
When I trigger the switch using the existing button on the wall, the state changes only in the root json pat but the other
set
stays the same - also Openhab doesn’t recognize the new state.
I just can’t figure out my mistake, even after searching everywhere on the forum or google.
