I wanted to expand my setup by sending TV channels to my DVR. (i.e.: sending simple numbers). I have downloaded the json which contains the commands which can be sent to specific devices. It says that my Cisco DVR can receive these ones and has the following format:
0: Number0
1: Number1
etc…
However when I try to send, nothing happens. openHab receives the command, sends it, but Harmony Hub is not blinking and sending the numbers. Anyone experienced something similar? Maybe I have missed something?
Ps.: How can I send multiple numbers? Just sendCommand x2 and sending the one number after another?
Well, you do not provide too much info of what version you are running, how your rule looks like and what the log says, if the command work from the remote itself, but this is my setup that works fine:
Thanks! It was just a dumb question…
Thing was setup through PaperUI. It works in other cases. The log didn’t provide any info, haven’t tried setting the level to debug.
My rule looks something like this:
rule “Set TV channel”
Item TV_Channel received command ON
Cisco.sendCommand(“Number5”)
