i have a problem to send temperature to the KNX-Bus.
my item is as follow:
Number Hannover_Temperatur “Temperatur [%.1f °C]” (Temperature_Aussen, HWR) {weather=“locationId=hannover, type=temperature, property=current”, knx=“0/0/3”}
my Config:
- Synology NAS mit Openhab 1.71
- Raspberry with Siemens BCU and eibd as Tunnel (0.0.0)
OH.cfg
################################ KNX Binding ##########################################
knx:ip=192.168.1.28
knx:ignorelocalevents=true
knx:type=TUNNEL
knxport=3671
knx:localIp=192.168.1.210
Weather
################################### Weather Binding ###################################
weather:apikey.OpenWeatherMap=geheimerschlüssel
weather:apikey.Wunderground=geheimerschlüssel
weather:location.hannover.name=Hannover
weather:location.hannover.latitude=52.3456
weather:location.hannover.longitude=9.7908
weather:location.hannover.provider=Wunderground
weather:location.hannover.language=de
weather:location.hannover.updateInterval=30
weather:location.leon.name=Leon
weather:location.leon.latitude=52.3456
weather:location.leon.longitude=9.7908
weather:location.leon.provider=OpenWeatherMap
weather:location.leon.language=de
weather:location.leon.updateInterval=30
but when i activate the items i get every second writes to KNX-Bus as follow:
20:14:59.648 [DEBUG] [.b.knx.internal.bus.KNXBinding:169 ] - Received groupWrite Event.
20:14:59.648 [INFO ] [tuwien.auto.calimero :51 ] - [KNXnet/IP receiver] link 192.168.1.28:3671: indication from 0.0.1
20:14:59.649 [WARN ] [.w.internal.bus.WeatherBinding:113 ] - Received command for readonly item Hannover_Temperatur, republishing state
20:14:59.650 [INFO ] [runtime.busevents :22 ] - Hannover_Temperatur received command 14.0
20:14:59.652 [DEBUG] [.b.knx.internal.bus.KNXBinding:113 ] - Received update (item=‘Hannover_Temperatur’, state=‘14.00’)
20:14:59.652 [INFO ] [tuwien.auto.calimero :51 ] - [EventAdmin Async Event Dispatcher Thread] link 192.168.1.28:3671: send message to 0/0/3, wait for confirmation
20:14:59.655 [INFO ] [tuwien.auto.calimero :51 ] - [KNXnet/IP receiver] link 192.168.1.28:3671: confirmation of 0/0/3
20:14:59.655 [DEBUG] [.b.knx.internal.bus.KNXBinding:138 ] - Wrote value ‘14.00’ to datapoint ‘command DP 0/0/3 Hannover_Temperatur, DPT main 0 id 9.001, low priority’
20:14:59.656 [INFO ] [runtime.busevents :26 ] - Hannover_Temperatur state updated to 14.00
20:14:59.687 [INFO ] [tuwien.auto.calimero :51 ] - [KNXnet/IP receiver] link 192.168.1.28:3671: indication from 0.0.1
20:14:59.687 [DEBUG] [.b.knx.internal.bus.KNXBinding:169 ] - Received groupWrite Event.
20:14:59.688 [WARN ] [.w.internal.bus.WeatherBinding:113 ] - Received command for readonly item Hannover_Temperatur, republishing state
20:14:59.689 [INFO ] [runtime.busevents :22 ] - Hannover_Temperatur received command 14.0
20:14:59.691 [DEBUG] [.b.knx.internal.bus.KNXBinding:113 ] - Received update (item=‘Hannover_Temperatur’, state=‘14.00’)
20:14:59.691 [INFO ] [tuwien.auto.calimero :51 ] - [EventAdmin Async Event Dispatcher Thread] link 192.168.1.28:3671: send message to 0/0/3, wait for confirmation
20:14:59.694 [INFO ] [tuwien.auto.calimero :51 ] - [KNXnet/IP receiver] link 192.168.1.28:3671: confirmation of 0/0/3
20:14:59.694 [DEBUG] [.b.knx.internal.bus.KNXBinding:138 ] - Wrote value ‘14.00’ to datapoint ‘command DP 0/0/3 Hannover_Temperatur, DPT main 0 id 9.001, low priority’
20:14:59.695 [INFO ] [runtime.busevents :26 ] - Hannover_Temperatur state updated to 14.00
20:14:59.726 [DEBUG] [.b.knx.internal.bus.KNXBinding:169 ] - Received groupWrite Event.
20:14:59.726 [INFO ] [tuwien.auto.calimero :51 ] - [KNXnet/IP receiver] link 192.168.1.28:3671: indication from 0.0.1
20:14:59.727 [WARN ] [.w.internal.bus.WeatherBinding:113 ] - Received command for readonly item Hannover_Temperatur, republishing state
20:14:59.728 [INFO ] [runtime.busevents :22 ] - Hannover_Temperatur received command 14.0
20:14:59.730 [DEBUG] [.b.knx.internal.bus.KNXBinding:113 ] - Received update (item=‘Hannover_Temperatur’, state=‘14.00’)
20:14:59.730 [INFO ] [tuwien.auto.calimero :51 ] - [EventAdmin Async Event Dispatcher Thread] link 192.168.1.28:3671: send message to 0/0/3, wait for confirmation
20:14:59.733 [INFO ] [tuwien.auto.calimero :51 ] - [KNXnet/IP receiver] link 192.168.1.28:3671: confirmation of 0/0/3
20:14:59.733 [DEBUG] [.b.knx.internal.bus.KNXBinding:138 ] - Wrote value ‘14.00’ to datapoint ‘command DP 0/0/3 Hannover_Temperatur, DPT main 0 id 9.001, low priority’
20:14:59.734 [INFO ] [runtime.busevents :26 ] - Hannover_Temperatur state updated to 14.00
20:14:59.765 [DEBUG] [.b.knx.internal.bus.KNXBinding:169 ] - Received groupWrite Event.
20:14:59.765 [INFO ] [tuwien.auto.calimero :51 ] - [KNXnet/IP receiver] link 192.168.1.28:3671: indication from 0.0.1
20:14:59.766 [WARN ] [.w.internal.bus.WeatherBinding:113 ] - Received command for readonly item Hannover_Temperatur, republishing state
20:14:59.767 [INFO ] [runtime.busevents :22 ] - Hannover_Temperatur received command 14.0
20:14:59.769 [DEBUG] [.b.knx.internal.bus.KNXBinding:113 ] - Received update (item=‘Hannover_Temperatur’, state=‘14.00’)
20:14:59.769 [INFO ] [tuwien.auto.calimero :51 ] - [EventAdmin Async Event Dispatcher Thread] link 192.168.1.28:3671: send message to 0/0/3, wait for confirmation
20:14:59.772 [INFO ] [tuwien.auto.calimero :51 ] - [KNXnet/IP receiver] link 192.168.1.28:3671: confirmation of 0/0/3
20:14:59.772 [DEBUG] [.b.knx.internal.bus.KNXBinding:138 ] - Wrote value ‘14.00’ to datapoint ‘command DP 0/0/3 Hannover_Temperatur, DPT main 0 id 9.001, low priority’
20:14:59.773 [INFO ] [runtime.busevents :26 ] - Hannover_Temperatur state updated to 14.00
So i don´t know how to solve the problem
gpowa
