I’m experimenting with my first OH3.2 on a Pi4 and am running into something strange.
I had a Sensibo API binding running, but removed it because I wanted to start anew.
Now, after adding the binding and adding my API key, the status goes to Unknown.
If I look in the log I find the following:
2022-02-01 13:49:03.068 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘sensibo:account:32af74fb34’ changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2022-02-01 14:02:30.204 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
at org.openhab.binding.sensibo.internal.model.SensiboSky.<init>(SensiboSky.java:74) ~[?:?]
at org.openhab.binding.sensibo.internal.handler.SensiboAccountHandler.refreshModel(SensiboAccountHandler.java:197) ~[?:?]
at org.openhab.binding.sensibo.internal.handler.SensiboAccountHandler.initializeInternal(SensiboAccountHandler.java:148) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515) ~[?:?]
Does the binding have dependencies?
