Thanks, but what is a PR??
PR = Pull request. Someone makes necessary changes to the code, and binding owner and someone from the OpenHab team do code review.
I found a Sensibo API Integration - Based on Rules Sensibo API Integration - Based on Rules
According to its maker it works on the v1 Pods, but is for OH2. Wouldnt that be a good startingpoint?
I bumped that 2 years old discussion, maybe itāll lead to a working solution ![]()
You will see that I did post in that tread and had mine working with rules for a long time. OH2 and 3 rule engine is the same so you can try and get them working. You may run into permission issue when running command line operations. Most people donāt have the hardware to be able to test to make sure their code is correct. I know you are a beginner however you need to start somewhere and getting it running in the rules would be a good start.
You could also try your luck on
Thanks, will give it a go and report my succes here ![]()
