I’d like to be able to monitor conventional water meter (Sensus 620) so I know the consumption and if the water is flowing (useful for leak detection). My water meter is Sensus 620 and I found the company also sells HRI sensor that can send pulses when water is being used. The model I think works for me is “Sensus HRI-B4/D10”. The HRI B models seems to support ModBus protocol, but it doesn’t provide USB interface. Has anybody here manage to use the HRI sensors in OpenHAB? How can I connect it to USB and which add-on do I need? Thank you in advance!
User manual: https://uploads-ssl.webflow.com/5da381e720ae1b539b3818c0/5efd517546b15208049b2473_DE%2C%20EN%2C%20ES%2C%20FR%20-%20HRI%20Manual.pdf
PS: I found some discussion on DIY approximation sensor however I’m not very technical so not something for me.
