I realise that the post is old (Last year), but it does say it was updated… And it appears to be consistent with the wording in the openhab2 logging page (http://docs.openhab.org/administration/logging.html)
zWave still logs with everything else into openhab.log and events.log. I’ve also tried to set zWave logging to DEBUG in the console (After eventually finding start_debug.sh and then working out it needs to be run as openhab, not as root because it doesn’t work when started as root)…
But nothing on the logging side changed…
openhab> set LEVEL DEBUG org.openhab.binding.zwave
openhab>
I think I’m losing my marbles here. Certainly the will to live… 2.2.0-1 appears to be anything but stable for me. And trying to determine why is driving me nuts.
Changing the logger and appender to use the same… And it’s no longer ignored… But still doesn’t work… I now have a new error on startup in the console…
penhab@piman-202:~$ /usr/share/openhab2/start_debug.sh
Launching the openHAB runtime...
Listening for transport dt_socket at address: 5005
13:58:22.989 [CM Configuration Updater (ManagedService Update: pid=[org.ops4j.pax.logging])] ERROR org.apache.felix.configadmin - [org.osgi.service.log.LogService, org.knopflerfish.service.log.LogService, org.ops4j.pax.logging.PaxLoggingService, org.osgi.service.cm.ManagedService, id=33, bundle=6/mvn:org.ops4j.pax.logging/pax-logging-log4j2/1.10.1]: Unexpected problem updating configuration org.ops4j.pax.logging
java.lang.StringIndexOutOfBoundsException: String index out of range: -1
at java.lang.String.substring(String.java:1967) [?:?]
at org.apache.logging.log4j.util.PropertiesUtil.partitionOnCommonPrefixes(PropertiesUtil.java:293) [5:org.ops4j.pax.logging.pax-logging-api:1.10.1]
at org.apache.logging.log4j.core.config.properties.PropertiesConfigurationBuilder.build(PropertiesConfigurationBuilder.java:155) [6:org.ops4j.pax.logging.pax-logging-log4j2:1.10.1]
at org.apache.logging.log4j.core.config.properties.PropertiesConfigurationFactory.getConfiguration(PropertiesConfigurationFactory.java:56) [6:org.ops4j.pax.logging.pax-logging-log4j2:1.10.1]
at org.ops4j.pax.logging.log4j2.internal.PaxLoggingServiceImpl.doUpdate(PaxLoggingServiceImpl.java:206) [6:org.ops4j.pax.logging.pax-logging-log4j2:1.10.1]
at org.ops4j.pax.logging.log4j2.internal.PaxLoggingServiceImpl.updated(PaxLoggingServiceImpl.java:158) [6:org.ops4j.pax.logging.pax-logging-log4j2:1.10.1]
at org.ops4j.pax.logging.log4j2.internal.PaxLoggingServiceImpl$1ManagedPaxLoggingService.updated(PaxLoggingServiceImpl.java:426) [6:org.ops4j.pax.logging.pax-logging-log4j2:1.10.1]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updated(ManagedServiceTracker.java:189) [7:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updateService(ManagedServiceTracker.java:152) [7:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.provideConfiguration(ManagedServiceTracker.java:85) [7:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.provide(ConfigurationManager.java:1479) [7:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.run(ConfigurationManager.java:1435) [7:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:141) [7:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:109) [7:org.apache.felix.configadmin:1.8.16]
__ _____ ____
____ ____ ___ ____ / / / / | / __ )
/ __ \/ __ \/ _ \/ __ \/ /_/ / /| | / __ |
/ /_/ / /_/ / __/ / / / __ / ___ |/ /_/ /
\____/ .___/\___/_/ /_/_/ /_/_/ |_/_____/
/_/ 2.2.0
Release Build
