I’m having issues with items using the Serial binding. It started after doing apt updates, but I’m not sure exactly when, but I do know my items still work on version 1.11.0.
I’m using RFlink (not the binding) to switch on and off some 433mhz plugs and listening for my doorbell.
I’m using a combination of rules and items with ON/OFF statements.
an example of a switch:
Switch RFoffice “KontorRF” (Smappee) { serial="/dev/ttyACM0@57600,ON(10;NewKaku;011d9428;1;ON;\n),OFF(10;NewKaku;011d9428;1;OFF;\n)" }
This is the item I use to sniff for data to parse in a rule:
String RFLinkRaw “RF [%s]” { serial="/dev/ttyACM0@57600" }
It seems like all 433mhz traffic is captured by RFLink and passed on correctly and the OFF commands to items also seem to be confirmed by RFlink via a ‘RFLinkRaw changed from 20;14;OK;
to 20;15;OK;’, but only rarely the ON command gets any feedback from RFLink.
This means that I can turn stuff off but not on. It doesn’t help sending it from a rule either.
Any ideas?
Best regards
