- Platform information:
- Hardware: eeePC i.e. ATOM N270 CPU, 2GB RAM. Planning move to RaspberryPI4 later
- OS: 32-bit Windows 10 Pro, eeePC does not support 64-bit
- Java Runtime Environment: Zulu 11.0.14
- openHAB version: 3.4.1
- Issue of the topic: I am running rollershutters from Selve through a serial interface.
The serial binding is working as I can control the rollershutters from OpenHAB successfully.
In the next step I am trying to read the rollershutter position which is sent back through the serial port.
I can see the messages when connecting to the serial port with hterm.
I configured an item in an attempt to see the received string and from there write a rule to extract the position of the rollershutter.
I think I am doing a very simple stupid mistake but I don’t get a hand on it.
Therefore the communities help is very much appreciated.
I prefer textual configuration over GUI-configuration. - My configurations are looking the following:
Binding and thing:
Bridge serial:serialBridge:SerialCOM3 “Serial Bridge Commeo” [serialPort=“COM3”, baudRate=115200, dataBits=8, stopBits=1, parity=“N”] {
Thing serial:serialDevice:SerialCOM3:SerialDeviceCommeo “Serial Device Commeo” [patternMatch=“<m” ] {
Channels:
Type string : SelveEmpfangsStringType rollershutter : RollladenDGStrasseRechts [upValue="<methodCall><methodName>selve.GW.command.device</methodName><array><int>0</int><int>1</int><int>1</int></array></methodCall>", downValue="<methodCall><methodName>selve.GW.command.device</methodName><array><int>0</int><int>2</int><int>1</int></array></methodCall>", stopValue="<methodCall><methodName>selve.GW.command.device</methodName><array><int>0</int><int>0</int><int>1</int></array></methodCall>"] Type rollershutter : RollladenDGStrasseLinks [upValue="<methodCall><methodName>selve.GW.command.device</methodName><array><int>1</int><int>1</int><int>1</int></array></methodCall>", downValue="<methodCall><methodName>selve.GW.command.device</methodName><array><int>1</int><int>2</int><int>1</int></array></methodCall>", stopValue="<methodCall><methodName>selve.GW.command.device</methodName><array><int>1</int><int>0</int><int>1</int></array></methodCall>"] Type rollershutter : RollladenDGGartenRechts [upValue="<methodCall><methodName>selve.GW.command.device</methodName><array><int>2</int><int>1</int><int>1</int></array></methodCall>", downValue="<methodCall><methodName>selve.GW.command.device</methodName><array><int>2</int><int>2</int><int>1</int></array></methodCall>", stopValue="<methodCall><methodName>selve.GW.command.device</methodName><array><int>2</int><int>0</int><int>1</int></array></methodCall>"] Type rollershutter : RollladenDGGartenLinks [upValue="<methodCall><methodName>selve.GW.command.device</methodName><array><int>3</int><int>1</int><int>1</int></array></methodCall>", downValue="<methodCall><methodName>selve.GW.command.device</methodName><array><int>3</int><int>2</int><int>1</int></array></methodCall>", stopValue="<methodCall><methodName>selve.GW.command.device</methodName><array><int>3</int><int>0</int><int>1</int></array></methodCall>"] } }
Items configuration:
String Test_item “Test Item [%s]” { channel=“serial:serialDevice:SerialCOM3:SerialDeviceCommeo:SelveEmpfangsString” } -
Sitemap configuration:
none yet -
Rules code:
none yet -
Services configuration:
none
