just had to reinstall my windows with openhab3 on it
so i installed the oh3 3.3.0 but the serial binding is not letting me set custom baud rate (2400)
i get
**HANDLER_CONFIGURATION_PENDING**
{baudRate=The value 2400.0 does not match allowed parameter options. Allowed options are: [ParameterOption [value="4800", label="4800"], ParameterOption [value="9600", label="9600"], ParameterOption [value="19200", label="19200"], ParameterOption [value="38400", label="38400"], ParameterOption [value="57600", label="57600"], ParameterOption [value="115200", label="115200"]]}
same error if i do it as a thing or if i edit the org.openhab.core.thing.thing.json to baudrate 2400
Hi Nick. Did you manage to find and edit the config validation for the serial binding? And how? I have the same issue after update from 3.2 to 3.3 but can’t find a solution (other than going back to 3.2)
Hey RegnarOxholm,
MikeJMajor has done an update with the binding on github. as im not use to github i dont know how to get the update from there to my system. i do think you can get the update of the code via snapshots though.
how did you download it? i downloaded it changed zip to jar but the system didnt show anything in the logs to say it was installed or not when put in the addons folder
