yesterday I ran the OpenHAB update from 2.2 to 2.3.
Unfortunately, I now have problems with the serial binding, which controls my light control in the house.
Since the update, a ‘)’ is sent to the OFF command, for example:
smarthome:send L_KG_Flur ON
smarthome:send L_KG_Flur OFF
I get the following logfile entries (linefeed removed):
2018-08-03 08:23:07.529 [DEBUG] [binding.serial.internal.SerialDevice] - Writing '!;36;1' to serial port /dev/ttyIOBox1
2018-08-03 08:23:12.837 [DEBUG] [binding.serial.internal.SerialDevice] - Writing '!;36;2)' to serial port /dev/ttyIOBox1
if i remove the ‘)’ from the item it works as expected:
I don´t have an answer, but I can confirm the behavior of the serial binding. Took me 2 hours to find out why my communication to the arduino doesn´t work as expceted.
My current solution: the Arduino filters the ‘)’ fromt the input string.
Triple confirm on this one. Looking forward to a future fix. For the time being I also remove the final ‘)’ from the OFF command in the .items definition. Phew - that debug took a while…
