Serial binding transformation problem OH3
I’m migrating to OH3 these days and have problems getting the regex functionality to extract the data I need from my RFLink setup. Does anyone have a working example with sensors and switches using RFLink?
I tried this thing, and it returns the whole string, not the temperature number. It seems as no matter what regex expression I put in, it returns the whole string.
Thing serialDevice temperatureSensor [patternMatch=“20;05;Cresta;ID=2801;."] {
Channels:
Type string : temperature [transform="REGEX:.
?TEMP=(.?);.”]
Have you tried using the example in the documentation for the serial binding?
Type number : temperature [transform="REGEX:.*?TEMP=(.*?);.*"]
Do you have the regex transformation installed? Enabling DEBUG logging for the serial binding should give some more info in the openhab log.
Of course I need the transformation! Thanks a lot for saving my day! :slight_smile:
Also, the example is wrong. In the example “on” and “off” is used instead of “onValue” and “offValue”. Also, “transform” should be “stateTransformation”. Anyone have access to fix that?
https://github.com/openhab/openhab-addons/pull/9949
