It’s my first OpenHAB install. I successfully configured my DIY temperature bluetooth sensor: data is show and updated in BasicUI.
I used serial bluetooth to connect to this sensor, so I used serial=“/dev/rfcomm0” in my items file.
The problem is when the sensor is disconnect, it will never be reconnected. The only way to get it reconnected is to reload my items file. So I use a dirty crontab hack:
*/5 * * * * touch /srv/openhab2-conf/items/default.items
Is there a better way to get my sensor reconnected ?
Maybe using expire binding to reload items file ?
Or another way to get serial connection restarted ?
Thanks for your help.
