Anyone know how to fix this? Things start off fine, but after a while the error below starts showing up on every write. To fix it I have to force rereading of the item config file.
2017-02-07 14:03:30 ERROR o.o.b.s.internal.SerialDevice[:292]- Error writing 'U' to serial port /dev/ttyPort3: Input/output error in writeArray
2017-02-07 14:04:00 ERROR o.o.b.s.internal.SerialDevice[:292]- Error writing 'U' to serial port /dev/ttyPort3: Input/output error in writeArray
2017-02-07 14:04:30 ERROR o.o.b.s.internal.SerialDevice[:292]- Error writing 'U' to serial port /dev/ttyPort3: Input/output error in writeArray
2017-02-07 14:05:00 ERROR o.o.b.s.internal.SerialDevice[:292]- Error writing 'U' to serial port /dev/ttyPort3: Input/output error in writeArray
2017-02-07 14:05:30 ERROR o.o.b.s.internal.SerialDevice[:292]- Error writing 'U' to serial port /dev/ttyPort3: Input/output error in writeArray
2017-02-07 14:06:00 ERROR o.o.b.s.internal.SerialDevice[:292]- Error writing 'U' to serial port /dev/ttyPort3: Input/output error in writeArray
2017-02-07 14:06:30 ERROR o.o.b.s.internal.SerialDevice[:292]- Error writing 'U' to serial port /dev/ttyPort3: Input/output error in writeArray
2017-02-07 14:07:00 ERROR o.o.b.s.internal.SerialDevice[:292]- Error writing 'U' to serial port /dev/ttyPort3: Input/output error in writeArray
2017-02-07 14:07:30 ERROR o.o.b.s.internal.SerialDevice[:292]- Error writing 'U' to serial port /dev/ttyPort3: Input/output error in writeArray
2017-02-07 14:08:00 ERROR o.o.b.s.internal.SerialDevice[:292]- Error writing 'U' to serial port /dev/ttyPort3: Input/output error in writeArray
