This is my first post so hopefully I am posting to the forum correctly. I am having issues trying to implement what I thought was a fairly simple concept, receiving a serial string to update the state of OH items using the serial binding and rules. I am currently using OH v1.8. My setup consists of Arduino Nodes using GPIO to monitor contact closures. I am using RF links to another Arduino acting as a gateway that outputs a string on the UART to OH running on an RPI. I have the Arduino’s and links working well and the protocol I implemented works well. It is basically a CSV string of device type, node id, payload. I have the UART connection working as I can see the received string in the log file. I have detailed the error below and would appreciate some advice on how to resolve the errors and get this working. I should point out that this is my first time at working with java and my coding experience is limited to that I have gained working with Arduinos, so I could be way out of my depth here.
Here is the relevant item config:
String Arduino "Arduino [%s]" (Arduino_Grp) { serial="/dev/ttyAMA0", autoupdate="false" }
Contact Window_PU_ArduinoTEST "Arduino Test Input" <pump> (gPU, Windows)
I can update the test contact from the console with the expected result in the gui:
osgi> openhab update Window_PU_ArduinoTEST OPEN
Update has been sent successfully.
Here is the openhab.log inclusive of the error:
[DEBUG] [b.serial.internal.SerialDevice:225 ] - Received message ‘1,2,0’ on serial port /dev/ttyAMA0
[DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl:282 ] - store(Arduino_Grp), state = 1,2,0
[DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl:282 ] - store(Arduino), state = 1,2,0
[DEBUG] [m.r.internal.engine.RuleEngine:305 ] - Executing rule ‘Arduino UART RX Received’
[DEBUG] [o.m.s.Arduino UART RX Packet =:38 ] - 1,2,0
[ERROR] [o.o.c.s.ScriptExecutionThread :50 ] - Error during the execution of rule ‘Arduino UART RX Received’: For input string: “0”
This is the rule that I am using:
import org.openhab.core.library.types.*
import org.openhab.core.persistence.*
import org.openhab.model.script.actions.*
import org.joda.time.*
import java.util.*
import org.eclipse.xtext.xbase.lib.*
import org.openhab.core.items.*
import java.util.ArrayList.*
var String[] rxbuffer
rule "Arduino UART RX Received"
Item Arduino received update
//Item Arduino changed
logDebug("Arduino UART RX Packet =", Arduino.state.toString)
rxbuffer = Arduino.state.toString.split(",")
var int devid = new Integer(rxbuffer.get(1))
var int nodeid = new Integer(rxbuffer.get(2))
var int rxdata = new Integer(rxbuffer.get(3))
logDebug("devid =",+ devid) //generates error
// logDebug("nodeid =", nodeid) //generates error
// logInfo("rxdata =", rxdata) //generates error
if (nodeid == 2) {
// logDebug("Node ID Confirmed =", nodeid)
if (rxdata == 0) {
// logInfo ("Arduino RX String Confirmed")
postUpdate(Window_PU_ArduinoTEST OPEN)
else if (rxdata == 1) {
postUpdate(Windows_PU_ArduinoTEST CLOSED)
So I suspect that the rule fails whilst trying to split the 3rd char from the string. I have tried using different variable type such as var Number rxdata = new Integer(rxbuffer.get(3)) to no avail and I am at a loss as to what is going on here.
Thanks for any assistance the community provides.
