Of course you can. Even more useful is to shunt a specific bindings logs to it’s item file. See:
And the “Filter” field at the top of frontail.
I do recommend using tail -f or multitail on a terminal over frontail for over all flexibility. See How to watch and look through logging.
You have full control over what gets logged through many different avenues.
Since frontail is a third party app, you would have to take this to with them.
Not filling an issue does gall but guarantee it won’t get looked at and fixed though.
If you want guarantees, you have to do it yourself.
Well, you’ve given it a shot here. No one in the forum so far has been able to give you any more information. And even if we were, we couldn’t fix it for you. So the next step is to file an issue with the information you do have.
I’m personally not convinced it isn’t working as designed. If it is, the devs will respond to the issue saying so. If it isn’t, they will have a look. But if they can’t reproduce the behavior their setup, their hands are tied. They can’t fix a behavior they cannot reproduce. And there are more than 350! (350 factorial, a number larger than all the grains of sand in the world) possible configurations of OH, which doesn’t count Rules and treats each binding as only one.
You will see bindings reloading every minute, as had been mentioned several times on this thread. You will also see a failed to load binding error log message. This is not what you are experiencing but it is a common problem a number if people experienced when they upgraded and didn’t notice the warning that the rest API docs moved.
