- Platform information:
- Hardware: Raspi2 B
- OS: Buster
- Java Runtime Environment: Zulu Embedded 8.25.0.76-linux-aarch32hf
- openHAB version: 2.5.3
First of all thanks to all the developers for this amazing platform!
2 weeks ago I started to connect my KNX smart home to a RapPi running openHAB 2
Controlling dimmable unicolor led’s works fine.
But now I become desperate in controlling a RGBW actor.
At first I thought it must be a problem with the colorpicker.
To verify this, I build a rule to set the HSB value manually.
I got the same result i.e. the actor didn’t do what I want…
Here are the inputs (HSBType) and outputs (KNX telegrams)
HSB KNX(H,S,B) SUPPOSED TO BE
3,90,50 7F 12 0C red with half brightness
119,90,50 0E 7F 0C green with half brightness
241,90,50 0E C 7F blue with half brightness
241,0,10 FF FF FF bright white
241,100,100 04 00 FF bright blue
241,0,10 19 19 19 dark with
241,0,0 00 00 00 off
The lamp took always the color sent on the KNX bus.
And this is quite different to the HSB value I sent to the color item.
For many hours I tried to search for similar reports here in the forum.
I found only some older posts (2018) regarding HSBType .
At least here is the code of my settings and the KNX log:
knx.things
Bridge knx:ip:bridge “Weinzierl KNX730 IP-IF” @ “KNX”[
type=“TUNNEL”,
ipAddress=“192.168.178.29”,
portNumber=3671,
localIp=“192.168.178.50”,
autoReconnectPeriod=60,
localSourceAddr=“1.1.252”
Thing device KNX_Line_1_1 @ “KNX” [
//fetch=true,
//pingInterval=300,
//readInterval=0
// AKD Dimm4_Aktor 1.1.8 Decke innen
Type switch : AKD4_8_switch “Decke rechts” [ ga=“1.001:1/1/2+<1/2/20” ]
Type color : AKD4_8_hsv “Decke rechts” [ switch=“1/1/2+<1/2/20”, hsb=“1/3/17+<1/2/21”, position=“1/3/16+<1/2/19” ]
Type dimmer : AKD4_8_Habs “Decke rechts” [ position=“5.003:1/3/14+<1/2/17” ]
Type dimmer : AKD4_8_Sabs “Decke rechts” [ position=“1/3/15+<1/2/18” ]
Type dimmer : AKD4_8_Vabs “Decke rechts” [ position=“1/3/16+<1/2/19” ]
home.items
Color LivingRoom_rightLight “Licht” (H_LivingRoom, gLight) [“Lighting”, “Switchable”] {channel=“knx:device:bridge:KNX_Line_1_1:AKD4_8_hsv”}
Switch LivingRoom_rightLight_Sw “Licht” (H_LivingRoom, gLight) [“Lighting”, “Switchable”] {channel=“knx:device:bridge:KNX_Line_1_1:AKD4_8_switch”}
Dimmer LivingRoom_rightLight_H “Licht” (H_LivingRoom, gLight) [“Lighting”] {channel=“knx:device:bridge:KNX_Line_1_1:AKD4_8_Habs”}
Dimmer LivingRoom_rightLight_S “Licht” (H_LivingRoom, gLight) [“Lighting”] {channel=“knx:device:bridge:KNX_Line_1_1:AKD4_8_Sabs”}
Dimmer LivingRoom_rightLight_V “Licht” (H_LivingRoom, gLight) [“Lighting”] {channel=“knx:device:bridge:KNX_Line_1_1:AKD4_8_Vabs”}
virtual.items
virtual items for the rules
Number LivingRoom_rightSzene “Licht” (H_LivingRoom, gLight) [“Lightning”]
Number LivingRoom_leftSzene “Licht” (H_LivingRoom, gLight) [“Lightning”]
light.rules
var DecimalType hue
var PercentType sat
var PercentType value
rule “chooseRightCeilColor”
Item LivingRoom_rightSzene received command
logInfo(“Deckenlampe innen”, triggeringItem.name.toString, “erhielt Kommando”, receivedCommand.toString)
switch(receivedCommand.toString) {
case “0”: {
//logInfo(“color item set to OFF”, hue.toString)
hue = new DecimalType(0)
sat = new PercentType(0)
value = new PercentType(0)
case “1”: {
//logInfo(“color item set to RED: h=3, s=90, b=50”)
hue = new DecimalType(3)
sat = new PercentType(90)
value = new PercentType(50)
case “2”: {
//logInfo(“color item set to green: h=119, s=90, b=50”)
hue = new DecimalType(119)
case “3”: {
//logInfo(“color item set to blue: h=241, s=90, b=50”)
hue = new DecimalType(241)
case “4”: {
//logInfo(“color item set to blue: h=241, s=0, b=100”)
value = new PercentType(100)
case “5”: {
//logInfo(“color item set to blue: h=241, s=100, b=100”)
sat = new PercentType(100)
case “6”: {
//logInfo(“color item set to blue: h=241, s=0, b=10”)
value = new PercentType(10)
case “7”: {
//logInfo(“color item set to blue: h=241, s=0, b=0”)
LivingRoom_rightLight.sendCommand(new HSBType(hue,sat,value))
user.sitemap
Selection item=LivingRoom_rightSzene label=“Farbschema innen” icon=“colorpicker” mappings=[0=“Aus H=0,S=0,B=0”, 1=“rot H=3,S=90,B50”, 2=“grün H=119,S=90,B=50”, 3=“blau H=241,S=90,B=50”, 4=“blau S0, B10”, 5=“blau S100, B100”, 6=“blau S0, B10”, 7=“blau S0, B0”]
Is there anybody out there with similar problems or can give me hint where my fault is
And here is what happens on the KNX bus:
#,Time,Service,Flags,Prio,Source Address,Source Name,Destination Address,Destination Name,Rout,Type,Info,Iack
170,“11.06.2020 17:04:26,602”,vom Bus,S=4,Niedrig,1.1.252,-0,1/3/17,Decke innen HSV,6,GroupValueWrite,“00 00 00 | kein Tag, 00:00:00”,LL_ACK
172,“11.06.2020 17:04:26,836”,vom Bus,S=0,Niedrig,1.1.8,AKD-0424V.02 LED Controller 4 Kanäle/RGBW,1/2/21,Decke innen HSV,6,GroupValueWrite,“00 00 00, 00:00:00”,LL_ACK
181,“11.06.2020 17:11:32,075”,vom Bus,S=0,Niedrig,1.1.252,-0,1/3/17,Decke innen HSV,6,GroupValueWrite,“00 00 00 | kein Tag, 00:00:00”,LL_ACK
183,“11.06.2020 17:12:02,927”,vom Bus,S=4,Niedrig,1.1.252,-0,1/3/17,Decke innen HSV,6,GroupValueWrite,7F 12 0C,LL_ACK
185,“11.06.2020 17:12:03,163”,vom Bus,S=0,Niedrig,1.1.8,AKD-0424V.02 LED Controller 4 Kanäle/RGBW,1/2/21,Decke innen HSV,6,GroupValueWrite,7F 12 0C,LL_ACK
189,“11.06.2020 17:12:05,971”,vom Bus,S=0,Niedrig,1.1.252,-0,1/3/17,Decke innen HSV,6,GroupValueWrite,7F 12 0C,LL_ACK
191,“11.06.2020 17:12:44,873”,vom Bus,S=4,Niedrig,1.1.252,-0,1/3/17,Decke innen HSV,6,GroupValueWrite,0E 7F 0C,LL_ACK
193,“11.06.2020 17:12:45,133”,vom Bus,S=0,Niedrig,1.1.8,AKD-0424V.02 LED Controller 4 Kanäle/RGBW,1/2/21,Decke innen HSV,6,GroupValueWrite,0E 7F 0C,LL_ACK
196,“11.06.2020 17:12:47,917”,vom Bus,S=6,Niedrig,1.1.252,-0,1/3/17,Decke innen HSV,6,GroupValueWrite,0E 7F 0C,LL_ACK
200,“11.06.2020 17:13:32,631”,vom Bus,S=6,Niedrig,1.1.252,-0,1/3/17,Decke innen HSV,6,GroupValueWrite,0E 0C 7F,LL_ACK
202,“11.06.2020 17:13:33,295”,vom Bus,S=2,Niedrig,1.1.8,AKD-0424V.02 LED Controller 4 Kanäle/RGBW,1/2/21,Decke innen HSV,6,GroupValueWrite,0E 0C 7F,LL_ACK
205,“11.06.2020 17:13:35,671”,vom Bus,S=0,Niedrig,1.1.252,-0,1/3/17,Decke innen HSV,6,GroupValueWrite,0E 0C 7F,LL_ACK
210,“11.06.2020 17:14:13,717”,vom Bus,S=2,Niedrig,1.1.252,-0,1/3/17,Decke innen HSV,6,GroupValueWrite,FF FF FF,LL_ACK
212,“11.06.2020 17:14:14,911”,vom Bus,S=6,Niedrig,1.1.8,AKD-0424V.02 LED Controller 4 Kanäle/RGBW,1/2/21,Decke innen HSV,6,GroupValueWrite,FF FF FF,LL_ACK
216,“11.06.2020 17:14:16,763”,vom Bus,S=6,Niedrig,1.1.252,-0,1/3/17,Decke innen HSV,6,GroupValueWrite,FF FF FF>,LL_ACK
219,“11.06.2020 17:14:41,323”,vom Bus,S=4,Niedrig,1.1.252,-0,1/3/17,Decke innen HSV,6,GroupValueWrite,04 00 FF,LL_ACK
221,“11.06.2020 17:14:42,585”,vom Bus,S=0,Niedrig,1.1.8,AKD-0424V.02 LED Controller 4 Kanäle/RGBW,1/2/21,Decke innen HSV,6,GroupValueWrite,04 00 FF,LL_ACK
224,“11.06.2020 17:14:44,367”,vom Bus,S=6,Niedrig,1.1.252,-0,1/3/17,Decke innen HSV,6,GroupValueWrite,04 00 FF,LL_ACK
226,“11.06.2020 17:15:06,685”,vom Bus,S=2,Niedrig,1.1.252,-0,1/3/17,Decke innen HSV,6,GroupValueWrite,19 19 19 ,LL_ACK
231,“11.06.2020 17:15:08,221”,vom Bus,S=4,Niedrig,1.1.8,AKD-0424V.02 LED Controller 4 Kanäle/RGBW,1/2/21,Decke innen HSV,6,GroupValueWrite,19 19 19,LL_ACK
232,“11.06.2020 17:15:09,731”,vom Bus,S=6,Niedrig,1.1.252,-0,1/3/17,Decke innen HSV,6,GroupValueWrite,19 19 19,LL_ACK
236,“11.06.2020 17:15:31,027”,vom Bus,S=6,Niedrig,1.1.252,-0,1/3/17,Decke innen HSV,6,GroupValueWrite,FF FF FF,LL_ACK
238,“11.06.2020 17:15:32,227”,vom Bus,S=2,Niedrig,1.1.8,AKD-0424V.02 LED Controller 4 Kanäle/RGBW,1/2/21,Decke innen HSV,6,GroupValueWrite,FF FF FF,LL_ACK
243,“11.06.2020 17:15:34,105”,vom Bus,S=4,Niedrig,1.1.252,-0,1/3/17,Decke innen HSV,6,GroupValueWrite,FF FF FF,LL_ACK
245,“11.06.2020 17:15:53,727”,vom Bus,S=0,Niedrig,1.1.252,-0,1/3/17,Decke innen HSV,6,GroupValueWrite,“00 00 00 | kein Tag, 00:00:00”,LL_ACK
248,“11.06.2020 17:15:55,089”,vom Bus,S=6,Niedrig,1.1.8,AKD-0424V.02 LED Controller 4 Kanäle/RGBW,1/2/21,Decke innen HSV,6,GroupValueWrite,“00 00 00 | kein Tag, 00:00:00”,LL_ACK
252,“11.06.2020 17:15:56,793”,vom Bus,S=6,Niedrig,1.1.252,-0,1/3/17,Decke innen HSV,6,GroupValueWrite,“00 00 00 | kein Tag, 00:00:00”,LL_ACK
253,“11.06.2020 17:16:16,976”,Stop,Aufzeichnung wurde beendet,
Thanks in advance
Regina
