Set a custom icon in a floorplan with an expression
  • Platform information:
    • Hardware: Pi 4
    • OS: OpenHab pi
    • Java Runtime Environment: defauult
    • openHAB version: 3.1
  • Issue of the topic: I want to have a custom icon for a device on a floorplan that changes with state.
I am able to find information in documentation about custom icons and images for use in floorplans, but I specifically want to use a custom icon that will change with state. Does anyone have an example that I can work from?
Any information is appreciated, even a link to documentation that addresses this.
Thank you.
Maybe share the code for what you have so far? Makes it easier to assist.
I do not have any code so far. I am looking for a place to start. I have a working OpenHab system and a current floorplan, but I cannot find any information on where or how to use an expression. it would be a fairly simple expression (hope to make it more complicated as I go)
I have found the following, which might be what I need:
https://www.openhab.org/docs/configuration/items.html#dynamic-icons
I expected to need an expression to link an icon to a state, but perhaps this will work for custom icons as well.
I appreciate the response and as I looked for example expresions, I came across this.
Thank you,
As suspected, that page was the correct answer, and I merely missed it as I searched initially. Thank you for the help.
