I have the alpha icloud binding working fine on openhab 2.2. I have written the following rule to set my presence based on the distance from home in Meters. The problem is I get this error in the smarthome designer:
Multiple markers at this line
The method or field SteveSIPhoneIPhone7_DistanceFromHome is
undefined
no viable alternative at input ‘51’
Type mismatch: cannot convert from DecimalType to boolean
Here’s my code:
rule "Steve Presence"
Item SteveSIPhoneIPhone7_DistanceFromHome received update
if(SteveSIPhoneIPhone7_DistanceFromHome.state as DecimalType < 51){
sendCommand(Steve_is_home, ON);
else
sendCommand(Steve_is_home, OFF)
How did you define SteveSIPhoneIPhone7_DistanceFromHome? In a .items file or in PaperUI?
If you defined it in PaperUI, than unfortunately, Designer is not going to know anything about that Item. In that case you can safely ignore these errors.
If you defined it in a .items file then look for a typo in the name. Pay close attention to case.
rule "Lori Presence"
Item LoriSIPhoneIPhone6_DistanceFromHome changed
Lori_is_home.sendCommand(if(LoriSIPhoneIPhone6_DistanceFromHome.state <= 50) ON else OFF)
