I have tried that as well, with a number of options but I can’t find the correct setup.
I have tried with both topic DPS 101 and DPS 102
I have tried add channel from Generic MQTT Thing with channel type rollershutter, percentage value, number value
I have tried to add point from semantic model (with above different channel types) and tried to change type to, dimmer, rollershutter etc.
MQTT Explorer
When I add the setup as dimmer, the command in DPS 102 change to the right number, but the blinds will not start. Some setups, the blinds will start but they will go to its end, not stop and the command number.
In smartlife app/tuya app, I had to create a scene to get the blinds to stop in a exact place. When I use that scene
MQTT Explorer change DPS 102 to FZ/ZZ (up/down) and DPS 101 = 0.
When the blinds are in the middle
DPS 102
State = STOP
DPS 101
State= 50
I have tried to use the STOP button in rollershutter, when the blinds are moving, but the blinds will not stop.
MQTT Explorer
DPS 102
state = FZ
command = STOP
The state will turn to STOP for a 1/2 of a second, then turn back to FZ and the blinds are still moving.
I add channel with value number
tuya/blinds/state
tuya/blinds/dps/101/command
(which show the state where the blinds are)
create thing with type number (not dimmer)
add a dummy switch
made a rule when dummy switch turn on, send command 70 to my item (tuya/blinds/dps/101/command) and the blind stops at 70.
I saw in MQTT explorer that when I used dimmer function, the command = 0.70 and not natural number 70. I could not figure it out how to get from 0.xxx to natural number with dimmer function.
