Set up colorpicker for mqtt device
  • Platform information:
    • Hardware: Raspberry Pi 4
    • openHAB version: 3.4.0
Hello together,
as I´m out of ideas after trying for hours i want to ask for help.
Im setting up a Tint Aris LED Panel. I use zigbee2mqtt to connect all my devices. On/Off and Brightness are already working fine but i stuck with the colors.
The panel supports color xy, rgb and hex. As i learned a colorpicker works with HSB. When i manually send a payload
{"color":{"r":255,"g":0,"b":0}}
to the panel with Mqtt.fx im able to change the color but im not able to set this up in my configuration.
There a lot of informations about HSB to RGB but i dont understand how to put these informations together to get the payload i need. Any ideas?
I tried a lot, this is my latest setup:
Items:
Switch                     LivingRoomMainLight            "Hauptlicht"                      <lightbulb>    (gLight,eLightLivingroom)            ["Light","Switch"]    {channel="mqtt:topic:livingroom:main_light"}
Dimmer                     LivingRoomMainBrightness       "Helligkeit Hauptlicht [%s]"      <lightbulb>    (eLightLivingroom)                   ["Light"]             {channel="mqtt:topic:livingroom:main_light_brightness", ga="Light", synonyms="Hauptlicht", roomHint="Wohnzimmer"}
Color                      LivingRoomMainLightColor       "Farbe"                           <lightbulb>    (eLightLivingroom)                   ["Light"]             {channel="mqtt:topic:livingroom:main_light_color2", ga="Light", synonyms="Hauptlicht Farbe", roomHint="Wohnzimmer"}
Things:
Thing  mqtt:topic:livingroom "MQTT Living Room" (mqtt:broker:Zigbee2Mqtt) {
    Channels:
//mueller licht
        Type switch : main_light    "Hauptlicht"    [ stateTopic="zigbee2mqtt/LivingRoomMain/state", commandTopic="zigbee2mqtt/LivingRoomMain/set", on="ON", off="OFF"]
        Type dimmer : main_light_brightness "Hauptlicht Helligkeit" [ stateTopic="zigbee2mqtt/LivingRoomMain", transformationPatternOut="JS:openhabdimmer2zigbeebridge.js", transformationPattern="JS:tradfri2openhab.js" ,commandTopic="zigbee2mqtt/LivingRoomMain/set", min=0, max=100, step=1]
        Type color : main_light_color2   "Hauptlicht Farbe" [ stateTopic="zigbee2mqtt/LivingRoomMain", commandTopic="zigbee2mqtt/LivingRoomMain/set", transformationPattern="JSONPATH:$.color", colorMode="RGB", formatBeforePublish="{\"color\":{\"r\":255,\"g\":0,\"b\":0}}"] //
        Type string : main_light_effect "Hauptlicht Effekt" [ stateTopic="zigbee2mqtt/LivingRoomMain", commandTopic="zigbee2mqtt/LivingRoomMain/set", transformationPattern="JSONPATH:$.effect" ]
Sitemap:
Colorpicker item=LivingRoomMainLightColor label="Farbe" icon="colorwheel"
Actual error message within zigbee2mqtt:
2023-02-04 08:57:59</small>`Publish 'set' 'color' to 'LivingRoomMain' failed: 'Error: Value does not contain valid color definition'`
Default pattern for formatBeforePublish for RGB: "%1$d,%2$d,%3$d"
"{\"color\":{\"r\":%1$d,\"g\":%2$d,\"b\":%3$d}}" might work.
good hint. i guess i had kinda double color attribut in my transformation.
This one is working:
Item:
Color                      LivingRoomMainLightColor       "Farbe"                           <lightbulb>    (eLightLivingroom)                   ["Light"]             {channel="mqtt:topic:livingroom:main_light_color", ga="Light", synonyms="Hauptlicht Farbe", roomHint="Wohnzimmer"}
Thing:
Type color : main_light_color   "Hauptlicht Farbe" [ stateTopic="zigbee2mqtt/LivingRoomMain/color", commandTopic="zigbee2mqtt/LivingRoomMain/set", colorMode="RGB", formatBeforePublish="{\"color\":{\"r\":%1$d,\"g\":%2$d,\"b\":%3$d}}"]
I’m having the same issue, but this solution haven’t worked for me. I know I’m close, maybe someone could give me a hint. I’m a total noob in transformations, jsonpaths and all that creepy stuff.
In MQTT explorer, if I send
zigbee2mqtt/TVLight/set
{"color":{"r":255,"g":0,"b":100}}
The colors change and I can see in MQTT explorer that the correct MQTT path is addressed:
TVLight = {"brightness":191.25,"color":{"h":352,"hue":352,"s":100,"saturation":100,"x":0.6224,"y":0.2634},"color_mode":"xy","color_power_on_behavior":"initial","color_temp":136,"do_not_disturb":false,"linkquality":54,"state":"ON"}
get = {"state": ""}
set = {"color":{"r":255,"g":0,"b":100}}
However, when I try to do it via the OpenHab item, the “set” item is addressed incompletely:
get = {"state": ""}
set = 84,99,83
Any idea what am I doing wrong? My configuration:
Thing:
UID: mqtt:topic:My_Mosquitto:BBB-TESTE-DIMMER
label: Generic MQTT Thing
thingTypeUID: mqtt:topic
configuration: {}
bridgeUID: mqtt:broker:My_Mosquitto
channels:
  - id: BBB-TESTE-STATE
    channelTypeUID: mqtt:switch
    label: BBB-TESTE-STATE
    description: BBB-TESTE-STATE
    configuration:
      commandTopic: zigbee2mqtt/TVLight/set
      stateTopic: zigbee2mqtt/TVLight/get
  - id: BBB-TESTE-DIMMER
    channelTypeUID: mqtt:dimmer
    label: BBB-TESTE-DIMMER
    description: BBB-TESTE-DIMMER
    configuration:
      commandTopic: zigbee2mqtt/TVLight/set/brightness
      min: 0
      stateTopic: zigbee2mqtt/TVLight/get/brightness
      max: 255
  - id: BBB-Color-Teste
    channelTypeUID: mqtt:color
    label: BBB-Color-Teste
    description: BBB-Color-Teste
    configuration:
      Type color: main_light_color   "label" [ stateTopic="zigbee2mqtt/TVLight/color",
        commandTopic="zigbee2mqtt/TVLight/set", colorMode="RGB",
      colorMode: RGB
Item:
type: Color
category: colorwheel
groupNames: []
tags:
  - Point
The item profile is defined as default. I guess I should use jsonpath instead, but have no idea what expression to include there.
Any hint will be welcomed! I think I’m close.
Cheers,
Got it (by a lot of tentative/error)
configuration: {}
channels:
    configuration:
    configuration:
      min: 0
      max: 255
    configuration:
      colorMode: RGB
      formatBeforePublish: '{"color": {"r":%1$d,"g":%2$d,"b":%3$d}}'
      transformationPattern: JSONPATH:$.color
The profile in the item is default (no transformation).
With this configuration, I’m able to:
  • Switch on/off
  • Dim light intensity
  • Change color
Hope it helps someone that has the same difficulty as myself.
