Hi there,
is there anyone who can help me to get channels configured for my doorsensor(s)?
I managed to get the according thing set up in OpenHab and it shows “online”, but that’s it.
I would really like to have something like, send a notification (to Telegram Channel?) if the door opens as long as “security” is enabled. mosquitto shows me messages like that on the raspberry:
Client mosqsub|5205-raspberryp received PUBLISH (d0, q0, r0, m0, ‘zigbee2mqtt/bridge/logging’, … (198 bytes))
{“level”:“info”,“message”:“MQTT publish: topic ‘zigbee2mqtt/ZigbeeStick01’, payload ‘{“battery”:100,“battery_low”:false,“contact”:false,“linkquality”:55,“tamper”:false,“voltage”:3000}’”}
Client mosqsub|5205-raspberryp received PUBLISH (d0, q0, r0, m0, ‘zigbee2mqtt/ZigbeeStick01’, … (98 bytes))
Client mosqsub|5205-raspberryp received PUBLISH (d0, q0, r0, m0, ‘zigbee2mqtt/bridge/logging’, … (197 bytes))
{“level”:“info”,“message”:“MQTT publish: topic ‘zigbee2mqtt/ZigbeeStick01’, payload ‘{“battery”:100,“battery_low”:false,“contact”:true,“linkquality”:42,“tamper”:false,“voltage”:3000}’”}
Client mosqsub|5205-raspberryp received PUBLISH (d0, q0, r0, m0, ‘zigbee2mqtt/ZigbeeStick01’, … (97 bytes))
Sometimes I get them displayed in the Event Monitor in OpenHab as well. I have set up the MQTT Broker succesfully, it seems.
But I have no clue what to set in the Channel configuration:
MGTT State Topic: ? - I have: zigbee2mqtt/ZigbeeStick01/contact
Custom On/Open Value: ? - I have: true
Custom Off/Closed Value: ? - I have: false
But the Item I added always says “NULL”
Any hint would be really appreciated!
- Platform information: OpenHab on Synology NAS, CC2531 USB Stick on Raspberry
- Hardware: enough
- OS: what OS is used and which version
- Java Runtime Environment: which java platform is used and what version
- openHAB version: 3.10
- Issue of the topic: How to get the channels configured?
- Please post configurations (if applicable):
UID: mqtt:topic:5853b352e1:3b7401a072
label: Türsensor 1 Esszimmer Rechts
thingTypeUID: mqtt:topic
configuration: {}
bridgeUID: mqtt:broker:5853b352e1
channels:- id: Tuerstatus
channelTypeUID: mqtt:contact
label: Tür Status
description: “”
configuration:
stateTopic: zigbee2mqtt/ZigbeeStick01/contact
off: “false”
on: “true”
- id: Tuerstatus
