Basic issue:
Clicking UP or DOWN has no effect in Number Picker for a Setpoint of un-initialized Number item.
It used to work before updated runtime and add-ons in Feb. The previous behavior - the first Number Picker click would set the MinValue.
Server side - openhab1. UI side is either Android or Basic UI, same behavior.
Background/usability impact:
Eco setpoint is often not reported by Honeywell zwave thermostats. With previous behavior of the Number Picker I was able to set it manually. With current behavior un-initialized Setpoint can’t be “fixed” via UI.
Item:
Number GrandRoomSetPointEco "Set Eco Temperature [%d °F]" <current_temp> {zwave="4:command=thermostat_setpoint,setpoint_type=11,setpoint_scale=1"}
Sitemap
Setpoint item=GrandRoomSetPointEco minValue=45 maxValue=55 step=1 visibility=[GrandRoomMode==11]
A warning shows up in log file for each up/down click:
WARN .w.internal.servlet.CmdServlet: Received unknown command 'Uninitialized' for item 'GrandRoomSetPointEco'
Item GrandRoomSetPointEco is not referenced in any rule.
Appreciate guidance to resolve!
Thx
