Setpoint with negative min and positiv max value
please help how should be set this parametrisation from setpoint (example as setpoint shift value from heating thermostat)
Setpoint item=Temperature_Setpoint minValue=-10 maxValue=10 step=1
Is not working for me for negative values.
Thanks,
Jozef
I am using the same syntax and it works very well in OH 1.8.3. What OH version are you using?
Have you tried adding “.0” in the minValue and MaxValue? I think I have encountered the same issue with integers!
Something like:
Setpoint item=offset label="Offset - SP [%.1f °C]" minValue=-5.0 maxValue=5.0 step=1
Best regards,
George
Hmm…
It works or it doesn’t?
I have this setpoint in OH1:
Setpoint item=spp_plCorrection	minValue=-2 maxValue=2 step=0.01
Only goes from 2 to 0 but not negative.
I want to use this setpoint to set a dollar value…
Yes it works…
This link: allow negative values for setpoint widget ranges by kaikreuzer · Pull Request #2390 · openhab/openhab1-addons · GitHub
has the solution…
add .0 to the negative value, like so:
Setpoint item=spp_plCorrection	minValue=-2.0 maxValue=2 step=0.01
I tested @Max_G 's solution as I head the same issue and it works fine with the added .0
