hello cloudknowledge!
I am running the openhabian-image on a raspi2 and have the folloging problem:
*) I created an analog-setpoint-item (more then one, to be honest), but they are not being mapped/included with the following error:
2017-04-08 19:21:51.723 [ERROR] [el.item.internal.GenericItemProvider] - Binding configuration of type ‘souliss’ of item ‘SoulissBilgeMinLevel’ could not be parsed correctly.
at org.openhab.binding.souliss.internal.SoulissGenericBindingProvider.processBindingConfiguration(SoulissGenericBindingProvider.java:92)[232:org.openhab.binding.souliss:1.9.0]
2017-04-08 19:21:51.730 [ERROR] [el.item.internal.GenericItemProvider] - Binding configuration of type ‘souliss’ of item ‘SoulissBilgeMaxLevel’ could not be parsed correctly.
2017-04-08 19:21:51.736 [ERROR] [el.item.internal.GenericItemProvider] - Binding configuration of type ‘souliss’ of item ‘SoulissAFactor’ could not be parsed correctly.
2017-04-08 19:21:51.741 [ERROR] [el.item.internal.GenericItemProvider] - Binding configuration of type ‘souliss’ of item ‘SoulissVFactor’ could not be parsed correctly.
the items look like:
Number SoulissBilgeMinLevel “BilgeMinLevel” (TechnicView_Node0) {souliss=“T61:0:18”}
Number SoulissBilgeMaxLevel “BilgeMaxLevel” (TechnicView_Node0) {souliss=“T61:0:20”}
Number SoulissAFactor “A-Factor” (TechnicView_Node0) {souliss=“T61:0:22”}
Number SoulissVFactor “V-Factor” (TechnicView_Node0) {souliss=“T61:0:24”}
problem2:
the item
Number SoulissBilgeLevel “Bilge Level” (gPrrd4jPersistanceEnable, TechnicView_Node0) {souliss=“T51:0:16”}
is not being processed
any ideas ?
(all items work in the souliss-app)
regards
Peter
Update!
did an update with the new repository… same s*, different day
never the less, the errors changed
2017-04-08 22:03:02.211 [ERROR] [el.item.internal.GenericItemProvider] - Binding configuration of type ‘souliss’ of item ‘SoulissBilgeMinLevel’ could not be parsed correctly.
at org.openhab.binding.souliss.internal.network.typicals.StateTraslator.stringToSOULISSTypicalCode(StateTraslator.java:51)[226:org.openhab.binding.souliss:1.10.0.201702140757]
at org.openhab.binding.souliss.internal.SoulissGenericBindingProvider.processBindingConfiguration(SoulissGenericBindingProvider.java:78)[226:org.openhab.binding.souliss:1.10.0.201702140757]
2017-04-08 22:03:02.215 [ERROR] [el.item.internal.GenericItemProvider] - Binding configuration of type ‘souliss’ of item ‘SoulissBilgeMaxLevel’ could not be parsed correctly.
2017-04-08 22:03:02.219 [ERROR] [el.item.internal.GenericItemProvider] - Binding configuration of type ‘souliss’ of item ‘SoulissAFactor’ could not be parsed correctly.
2017-04-08 22:03:02.224 [ERROR] [el.item.internal.GenericItemProvider] - Binding configuration of type ‘souliss’ of item ‘SoulissVFactor’ could not be parsed correctly.
