I’ve got a template widget setup in HABPanel and can move the bottom right corner around to adjust the size but the length/width of the box seems to snap into place. Its either too big or too small for my code.
Is there a way to unsnap the size so you can set it to any custom size?
HABPanel uses a grid layout, so you can only adjust widgets to some number of grid spaces. You can use the “Advanced” tab in the dashboard properties to increase the number of columns which will make the grid spaces smaller.
