PLeusmann
(P Leusmann)
January 11, 2017, 10:32pm
1
I want to set the target temperature on a HM-TC-IT-WM-W-EU wall thermostat. I am using the Homematic binding with Homegear.
This is the item definition:
Number Wohnzimmer_SET_TEMP "Soll-Temperatur [%.1f °C]" (Grp_Wohnzimmer) { homematic="MEQ1835202, channel=2, parameter=SET_TEMPERATURE"}
and the setpoint definition in the sitemap:
Setpoint item=Wohnzimmer_SET_TEMP label="Soll-Temperatur Wohnzimmer [%.1f °C]" step=0.5 minValue=15 maxValue=30
Problem is, openhab does not even show the current value for the data point. As a result, I cannot change it.
Anyone has a suggestion how to fix this?
What I experienced, when trying to read the value directly with homegear, is that getValue (https://www.homegear.eu/index.php/GetValue ) throws an exception when called with requestFromDevice = true. Is it possible the binding is using this parameter?
rlkoshak
(Rich Koshak)
January 12, 2017, 9:33pm
2
I can’t help with the homematic part of the problem. But I can say that a setpoint will not work until your Number Item has a value other than NULL.
While trying to figure out the homematic part of the problem I recommend putting the Item on your sitemap as a Text for now and not moving to a setpoint until the -
turns to a number.
patrickse
(Patrickse)
January 13, 2017, 7:13pm
3
Which version of homegear are you using and have you tried to show the value inside the homegear console. I’ve got the same device running for 2 years now, with oh1 and oh2.
PLeusmann
(P Leusmann)
January 17, 2017, 8:38pm
4
I am running Homegear 0.6.12. I can read the value using
$hg->getValue(<peer id>, 2, "SET_TEMPERATURE", false)
When using
$hg->getValue(<peer id>, 2, "SET_TEMPERATURE", true)
instead, homegear throws an exception.
patrickse
(Patrickse)
January 18, 2017, 6:46pm
5
Hmm. I am using 0.6.7 and I can set temperature through openhab without any problem. I will try your PHP commands later. Haven’t used the PHP interface for a while now.
PLeusmann
(P Leusmann)
January 22, 2017, 2:43pm
6
Did you already have the chance to try it?
Please post your item and Setpoint definition, if you were successful.
Thanks,
Philipp
patrickse
(Patrickse)
January 22, 2017, 7:54pm
7
Sorry… two little ones at home and no free time up to now…
I´ve just tried to fire these scripts… but I can actually not find how to execute this. Could you give me a hint?
Here´s my item definition…
Number lR_Wandthermostat_RSSI "lR_Wandthermostat RSSI [%d dBm]" <signal> (lR,W,gRSSI) { channel="homematic:HG-HM-TC-IT-WM-W-EU:homegear:LEQXXXXXX:0#RSSI_DEVICE" }
Switch lR_Wandthermostat_Unreach "lR_Wandthermostat unreachable" <siren> (lR,W,gUnreach) { channel="homematic:HG-HM-TC-IT-WM-W-EU:homegear:LEQXXXXXX:0#UNREACH" }
Switch lR_Wandthermostat_Pending "lR_Wandthermostat config pending" <siren> (lR,W,gPending) { channel="homematic:HG-HM-TC-IT-WM-W-EU:homegear:LEQXXXXXX:0#CONFIG_PENDING" }
Number lR_Wandthermostat_Battery "lR_Wandthermostat Batteriezustand [%.1f V]" <battery> (lR,W,gBatterie) { channel="homematic:HG-HM-TC-IT-WM-W-EU:homegear:LEQXXXXXX:2#BATTERY_STATE" }
String lR_Wandthermostat_Fault "lR_Wandthermostat Fehlerwert [MAP(HM-CC-RT-DN.map):%s]" <error> (lR) { channel="homematic:HG-HM-TC-IT-WM-W-EU:homegear:LEQXXXXXX:4#FAULT_REPORTING" }
Number lR_Wandthermostat_ActTemp "lR_Wandthermostat Ist-Temperatur [%.1f °C]" <temperature> (lR,gHeatAct,lR_Heat) [ "CurrentTemperature" ] { channel="homematic:HG-HM-TC-IT-WM-W-EU:homegear:LEQXXXXXX:1#TEMPERATURE" }
Number lR_Wandthermostat_ActHum "lR_Wandthermostat Luftfeuchtigkeit [%.0f %%]" (lR) { channel="homematic:HG-HM-TC-IT-WM-W-EU:homegear:LEQXXXXXX:1#HUMIDITY" }
Number lR_Wandthermostat_SetTemp "lR_Wandthermostat Soll-Temperatur [%.1f °C]" <temperature> (lR,gHeatSet,lR_Heat) [ "TargetTemperature" ] { channel="homematic:HG-HM-TC-IT-WM-W-EU:homegear:LEQXXXXXX:2#SET_TEMPERATURE" }
Switch lR_Wandthermostat_Auto "lR_Wandthermostat Auto-Mode" <temperature> (lR) { channel="homematic:HG-HM-TC-IT-WM-W-EU:homegear:LEQXXXXXX:2#AUTO_MODE" }
Number lR_Wandthermostat_Manu "lR_Wandthermostat Manu-Mode [%.1f °C]" <temperature> (lR) { channel="homematic:HG-HM-TC-IT-WM-W-EU:homegear:LEQXXXXXX:2#MANU_MODE" }
Switch lR_Wandthermostat_BoostMode "lR_Wandthermostat Boost-Mode" <temperature> (lR) { channel="homematic:HG-HM-TC-IT-WM-W-EU:homegear:LEQXXXXXX:2#BOOST_MODE" }
Number lR_Wandthermostat_BoostTime "lR_Wandthermostat Boost-Restdauer [%d min]" <"clock-on"> (lR) { channel="homematic:HG-HM-TC-IT-WM-W-EU:homegear:LEQXXXXXX:2#BOOST_STATE" }
Switch lR_Wandthermostat_Lowering "lR_Wandthermostat Spar Modus" <temperature> (lR) { channel="homematic:HG-HM-TC-IT-WM-W-EU:homegear:LEQXXXXXX:2#LOWERING_MODE" }
Switch lR_Wandthermostat_Comfort "lR_Wandthermostat Konfort Modus" <temperature> (lR) { channel="homematic:HG-HM-TC-IT-WM-W-EU:homegear:LEQXXXXXX:2#COMFORT_MODE" }
Number lR_Wandthermostat_Mode "lR_Wandthermostat Betriebsart [MAP(HM-CC-RT-DN.map):%s]" <temperature> (lR,gHeatMode,lR_heat) [ "homekit:HeatingCoolingMode" ] { channel="homematic:HG-HM-TC-IT-WM-W-EU:homegear:LEQXXXXXX:2#CONTROL_MODE" }
Number lR_Wandthermostat_SetMode "lR_Wandthermostat Betriebsart Auswahl [MAP(HM-CC-RT-DN.map):%s]" <"heating-80"> (lR,gInitNone)
Number lR_Wandthermostat_Preset "lR_Wandthermostat Soll-Temperatur Schnellauswahl" <"heating-40"> (lR,gInitNone)
Number lR_Wandthermostat_EcoTemp "lR_Wandthermostat Spar-Temperatur [%.1f °C]" (lR,value_persist)
Number lR_Wandthermostat_ComfTemp "lR_Wandthermostat Komfort-Temperatur [%.1f °C]" (lR,value_persist)
String lR_Wandthermostat_Summary "lR_Wandthermostat Übersicht [%s]" <heating> (lR)
And here´s my sitemap
Setpoint item=lR_Wandthermostat_SetTemp label="Wohnzimmer" icon="temperature"
I´ve used the configs from @ThomDietrich … really good stuff… have a look
https://github.com/ThomDietrich/openhab-config
Thanks!
However, just so you know: My heating control was not bug free and overhauling it is on my todo list. Please do not expect the solution there to be perfect. I was planning to switch over to have the thermostat in MANU mode all the time and a schedule in openHAB. Hows your systems state?
patrickse
(Patrickse)
January 22, 2017, 9:42pm
9
It’s exactly what I do. I just use the manu mode and control the temperature by cron based rules and some switches for presence control.
But I really like your clean item scheme. Working good for me.
