I have been running openhabian 2.5 for several years with no problems. I’m just setting up openhabian 4.1 on a Rpi 3B+. I can see my TP-Link devices and have them added to Things. I have 2 ESP8266 devices that provide remote temperature and humidity readings. They use MQTT in their settings. I have installed Misquitto from the openhabian-config screen and via the Addon-Store. I am using the configuration settings from my version 2.5. Unfortunately, I cannot get the MQTT Broker to connect.
I’m trying to read as much as I can understand but a lot of this information is way over my head.
I’m getting a Not Authorized message. I entered the password when I loaded MQTT from the openhabian-config screen. At this point, I’m not sure what to do next. Any help would be greatly appreciated.
2024-03-26 20:57:44.689 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.1.103' with clientid fb9e7e82-92ec-4318-a1a2-8e4f2ae2641c
2024-03-26 20:57:44.683 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:broker:38c63fb5bf' changed from OFFLINE (COMMUNICATION_ERROR): CONNECT failed as CONNACK contained an Error Code: NOT_AUTHORIZED. to OFFLINE
2024-03-26 20:57:44.700 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:broker:38c63fb5bf' changed from OFFLINE to OFFLINE (COMMUNICATION_ERROR): CONNECT failed as CONNACK contained an Error Code: NOT_AUTHORIZED.
2024-03-26 20:58:43.960 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:broker:38c63fb5bf' changed from OFFLINE (COMMUNICATION_ERROR): CONNECT failed as CONNACK contained an Error Code: NOT_AUTHORIZED. to REMOVING
2024-03-26 20:58:43.968 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:broker:38c63fb5bf' changed from REMOVING to REMOVED
2024-03-26 20:58:43.981 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:broker:38c63fb5bf' changed from REMOVED to UNINITIALIZED
2024-03-26 20:58:44.008 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:broker:38c63fb5bf' changed from UNINITIALIZED to OFFLINE
2024-03-26 20:58:44.039 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:broker:38c63fb5bf' changed from OFFLINE to UNINITIALIZED (HANDLER_MISSING_ERROR)
2024-03-26 21:
