Setting up mqtt items syntax
Because the Zigbee Binding isn’t working with all Xiaomi Aqara devices, I decided to setup all my configuration through zigbee2mqtt and the mqtt binding.
Before I start with my problem, is there a way to use a normal, understandable syntax for the configuration? Like xml, json or yaml?
Okay back to my problem:
Currently my item looks like this:
Number THSensor "Temperature [%.2f °C]" {mqtt="<[broker:zigbee2mqtt/0x00158e12345065dd:state:JSONPATH($.temperature)]"}
But I found a syntax like this too and I’m confused, but nothing works:
Number THSensor "Temperature [%.2f °C]" {channel="mqtt:topic:broker:zigbee2mqtt/0x00158d00045065dd"}
Then I tried to set it up through PaperUI, that worked without problems. What do I wrong?
I also have a bit different question, maybe off-topic:
  1. is it possible to create variables inside the items file?
  2. is it possible to create things/items/channels (don’t know which I’m meaning) at once like the simple mode in PaperUI?
recent post
No. xxx.items files are for Items. Nothing else.
You can allow things to be discovered that can be discovered. Ordinary MQTT devices/services cannot be auto discovered.
I recommend using mqtt 2.4 and also adding this to your zigbee2mqtt ymal file to help with transformations:
experimental:
output: attribute
For more info and examples see this topic.
