I have test again some things and can’t find the failure. I have added the user “openhab” and “openhab2” to group “tty”, “dialout” and “uucp”. I have red different users and groups in the internet, so i have made everything.
I have checkt the both files which should be crated:
I have also set the rights for both files with “chmod 755 …”.
After that I have bought a new Z-Wave-Sticks and have tested it with the “Aeotec Z-Stick Gen5” and “Z-wave.me ZMEEUZB”, but it will not work. I get following message: “Status: OFFLINE - COMMUNICATION_ERROR Serial Error: Port /dev/ttyACM0 does not exist”.
Has anyone an idea what’s going wrong at my Synology?
I have again tested some things and need your help by interpretation. At the moment I’m working with obenHAB version 2.3.0.005, because Version 2.4 and 2.2 will not start. I can install them, but when i want to start it in the package manager it doesn’t work. Is there maybe another problem? I have installed it in the Smarthome folder and the public folder, but there are no difference.
I have again testet the script and I’think the script is working, at least I get no failures when I start it with /bin/sh /usr/local/etc/rc.d/S98openhabzwave.sh start
I can find than the zwavelog.txt with the content “ls -l /dev/ttyACM0” and when I use “ls -l /dev/ttyA*” I get folowing result:
crwxrwxrwx 1 openhab dialout 166, 0 Feb 6 18:02 /dev/ttyACM0
Can someone say me, if this is correct or has an idea what is going wrong?
