im running OH2.4 openhabian on a raspberry pi 4 and i’m totally new to OH.
I got everything running so far, exept one radiator thermostat. My office room has two heaters, each one has a tado thermostat. PaperUI discovered both of them, but when i add them as a thing, only one gets the online state. The other one keeps failing:
2019-10-26 12:39:19.756 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - transformation throws exception [transformation=org.eclipse.smarthome.transform.map.internal.MapTransformationService@1cf91ed, value=ON]
Anyone had that problem before?
Where do i find this? Or do you mean my .items for the heating?
Now i’m getting this: 2019-10-26 23:05:02.774 [hingStatusInfoChangedEvent] - ‘tado:zone:demo:2’ changed from INITIALIZING to OFFLINE (COMMUNICATION_ERROR): Could not connect to server due to Operation showZoneDetails failed with error 404
Sorry for the late answer and thank you for your effort.
I found the problem and didnt remeber this post i made.
If you have to thermostats in one room and set up one of them for temperatur-measurement, the other one will go offline. I deleted the thing and the error was gone.
