Using the knowledge gained here by going through various topics on Zigbee2mqtt and Xiaomi Aqara devieces, I am able to configure a Xiaomi Aqara Vibration sensor, attached it to postbox for following purposes:
- To know via notification when there is new post arrrived in postobox and also display the new post info on UI using sitemap
- To know via notification when post is collected and also display this info on UI using sitemap.
I’m using Zigbee2MQTT (https://koenkk.github.io/zigbee2mqtt/ ) to bridge Aqara sensors to MQTT and bind them to things and items in OpenHAB 2.5.3-1.
Currently I’m using following Xiaomi Aqara devices
- motion sensors
- contact sensors
- vibration sensors
xiaomivib.things
Thing topic postboxvib "Postbox" (mqtt:broker:mosquitto) @ "Xiaomi" {
Channels:
Type number : battery [ stateTopic="zigbee2mqtt/postboxvib", transformationPattern="JSONPATH:$.battery" ]
Type number : voltage [ stateTopic="zigbee2mqtt/postboxvib", transformationPattern="JSONPATH:$.voltage" ]
Type number : linkquality [ stateTopic="zigbee2mqtt/postboxvib", transformationPattern="JSONPATH:$.linkquality" ]
Type number : angle [ stateTopic="zigbee2mqtt/postboxvib", transformationPattern="JSONPATH:$.angle" ]
Type number : angle_x [ stateTopic="zigbee2mqtt/postboxvib", transformationPattern="JSONPATH:$.angle_x" ]
Type number : angle_y [ stateTopic="zigbee2mqtt/postboxvib", transformationPattern="JSONPATH:$.angle_y" ]
Type number : angle_z [ stateTopic="zigbee2mqtt/postboxvib", transformationPattern="JSONPATH:$.angle_z" ]
Type number : angle_x_absolute [ stateTopic="zigbee2mqtt/postboxvib", transformationPattern="JSONPATH:$.angle_x_absolute" ]
Type number : angle_y_absolute [ stateTopic="zigbee2mqtt/postboxvib", transformationPattern="JSONPATH:$.angle_y_absolute" ]
Type number : strength [ stateTopic="zigbee2mqtt/postboxvib", transformationPattern="JSONPATH:$.strength" ]
Type string : action [ stateTopic="zigbee2mqtt/postboxvib", transformationPattern="JSONPATH:$.action" ]
xiaomivib.items
//Vibation sesnor Items
Number postboxvib_battery "Battery Strength [%.1f %%]" <battery> {channel="mqtt:broker:mosquitto:postboxvib:battery"}
Number postboxvib_voltage "Volt Signal [%d mV]" {channel="mqtt:broker:mosquitto:postboxvib:voltage"}
Number postboxvib_linkquality "Link Quality [%d]" {channel="mqtt:broker:mosquitto:postboxvib:linkquality"}
Number postboxvib_angle "Angle [%d]" {channel="mqtt:broker:mosquitto:postboxvib:angle"}
Number postboxvib_angle_x "Angle X [%d]" {channel="mqtt:broker:mosquitto:postboxvib:angle_x"}
Number postboxvib_angle_y "Angle Y [%d]" {channel="mqtt:broker:mosquitto:postboxvib:angle_y"}
Number postboxvib_angle_z "Angle Z [%d]" {channel="mqtt:broker:mosquitto:postboxvib:angle_z"}
Number postboxvib_angle_x_absolute "Absolute X [%d]" {channel="mqtt:broker:mosquitto:postboxvib:angle_x_absolute"}
Number postboxvib_angle_y_absolute "Absolute Y [%d]" {channel="mqtt:broker:mosquitto:postboxvib:angle_y_absolute"}
Number postboxvib_strength "Strength [%d]" {channel="mqtt:broker:mosquitto:postboxvib:strength"}
String postboxvib_action "Action [%s]" {channel="mqtt:broker:mosquitto:postboxvib:action"}
2 dummy items were created to control the display of messages on UI using sitemaps:
dummy.items
String postin "[%s]" <returnpipe>
String postout "[%s]" <flowpipe>
Sitemap has following entries:
myhome.sitemaps
Frame label="Postbox" {
Default item=postin visibility=[postboxvib_action=="vibration", postboxvib_action=="drop"] icon="returnpipe"
Default item=postout visibility=[postboxvib_action=="tilt"] icon="flowpipe"
To get the notification of post arrival and removal, following rules have been implemented:
postbox.rules
rule "PostboxAction"
Item postboxvib_action changed
if(postboxvib_action.state=="vibration") {
sendNotification("xyz@web.de", "Post to Collect !!")
postin.postUpdate("New Post arrived @ " + now.toString("dd-MM-yyyy HH:mm:ss") + " !!")
if(postboxvib_action.state=="drop") {
if(postboxvib_action.state=="tilt") {
sendNotification("xyz@web.de", "Post Collected !!")
postout.postUpdate("Post Collected @ " + now.toString("dd-MM-yyyy HH:mm:ss") + ".")
Best regards, Sukkhi
