dpat123
(darshan)
February 25, 2017, 12:33pm
1
i am using openhab2 Sanp for ubuntu core on RPI3.
could your please explain after installing HomeKit add-on . do i have to create files manually
if so openhab2 is installed in snap/openhab/ → do i have to creat homekit config file
i am also not able to add new thing as it ask for bindings . do i have you create items file manually .
rlkoshak
(Rich Koshak)
February 27, 2017, 1:52am
2
There is nothing special with using the snap install for these things. Please see:
http://docs.openhab.org/tutorials/beginner/index.html
and
I have installed the home kit binding via Paper UI, but now I am trying to edit the homekit.cfg file, and I cannot find where it should go. I installed via apt-get, which from what I gather can make a difference in directory structure. I don’t appear to have a ‘conf’ folder anywhere on my system.
dpat123
(darshan)
March 2, 2017, 12:14pm
3
i have created these two files files .
/var/snap/openhab/current/conf/services/homekit.cfg
/var/snap/openhab/current/conf/items/demo.items
do i also have to create sitemap file . and then hot to link those items to things . anybody for help
rlkoshak
(Rich Koshak)
March 8, 2017, 4:17pm
4
Yes. You must create a .sitemap file as described in the beginner’s tutorial here
dpat123
(darshan)
March 10, 2017, 5:19am
5
Now OpenHab accessory has started showing in IOS Home App. it is detecting
it very nicely.
i wanted to now use MQTT boaker to send command to NodeMCU ESP8255 . that
will have relay fixed .
so working on it . now .
espagnol01
(Gonzalo Escudero)
December 8, 2017, 5:25pm
6
Hej @dpat123 , how did it go with this? Where you able to control your items on the mqtt network from the homekit app?
dpat123
(darshan)
December 9, 2017, 2:01am
7
Yes it works. Using mqtt.
martmiwp
(Michael )
June 12, 2018, 5:20pm
8
Hi all - using 2.3 -
a great video is showing how to setup homekit:
This really works great if you follow the instructions.
My question: How to add more items? I just added “Lighting” to more items in the items file, but had to reconfigure the iphone to get the new items visible…
Any thoughts how to bring them to life?
Michael
