I followed the following guide (http://docs.openhab.org/installation/linux.html#permissions) to enable network share on my Raspberry Pi to be able to access files from my Win 10 PC. So far, all went right but I´m not able to execute the following command:
The error shown is: pi@raspberrypi:~ $ sudo chown -hR openhab:openhab /etc/openhab2 /opt/openhab2/config
chown: Zugriff auf ‘/opt/openhab2/config’ nicht möglich: Datei oder Verzeichnis nicht gefunden
(File not found).
I searched via the search function for the folders, checked permissions on the openhab2 folders found who are correctly set to owner=openhab.
Can you please advise, how I can check the permissions manually? I have tried to mount the RasPi on my Windows PC, but the network drive cannot be found.
without any success. Is there any alternative way to do this step? I believe this is the reason, why the network share doesn´t work yet, as permissions are not correctly set. Any chance to do this using the desktop view of rasbian?
Solution: Realized that - for whatever reason - my logins weren´t accepted. I tried openhabian as login and the same as password and, tatatataaaaaa, it works!
