- Platform information:
- Hardware: RPi4
- OS: Openhabian
- openHAB version: 3.2.0
- Issue of the topic:
The Hue Emulation directly jumps toOfflinewith aConfiguration Error. The error message is (translated from German)Error to automatically create a new user name-
The log output gives:
2022-02-08 21:10:20.311 [WARN ] [ue.internal.handler.HueBridgeHandler] - Failed creating new user on Hue bridgeand in the next line:
java.io.IOException: Server returned HTTP response code: 405 for URL: http://192.168.178.69:8080/api/ -
Going directly to the address 192.168.178.69:8080/api/status gives:
Self test To access any links you need be in pairing mode! Pairing mode: Off (V2) Enable | Enable with bridge V1 emulation 5 published lights (see http://192.168.178.69:8080/api/testuser/lights) 103 published sensors (see http://192.168.178.69:8080/api/testuser/sensors) UPnP discovery test service not registered Reachability test URL Responds? Ours? http://192.168.178.69:8080/description.xml no no http://192.168.178.69/description.xml no no http://[fe80:0:0:0:e9a6:4856:f3cf:f310]:8080/description.xml no no http://[fe80:0:0:0:e9a6:4856:f3cf:f310]/description.xml no no http://[2001:4dd4:cf21:0:d9f6:2d12:92c6:8f85]:8080/description.xml no no http://[2001:4dd4:cf21:0:d9f6:2d12:92c6:8f85]/description.xml no no Users -
I used the nginx installation from openhabian but the error also shows up when I stop the nginx service.
Does anyone have an idea what could be wrong?
