- Platform information:
- Hardware: Raspberry Pi 4
- OS: OpenHabian 32bit 1.6.1
- Java Runtime Environment: ?
- openHAB version: 2.5.10-1
- Issue of the topic:
I first setup a OpenHab System (2.3.x) with z-wave devices and got it running. Since then the system has deteriorated quite a bit and is barely usable - unfortunatly.
Since the serial interface was/is an AEOTEC stick, I decided for a fresh start. I got another raspberry pi 4, got a Silicon Lab UZB-7 (Firmware 7.11).
I installed a running version with the above version numbers. The UZB-7 registers as online in the configuration. (I exclusively work in PaperUI)
However, I have severe troubles getting zwave devices to register. I tried for several weeks now. I have excluded one of the z-wave devices from the working setup (a devolo thermostat) and tried to include it into the new openHab.
The problem is, that during inclusion, the zwave device is discovered, but it does not initialise correctly and is therfore unusable.
After resetting the thermostat, I can include it with the AEOTEC interface, so I rule out a faulty thermostat.
So since it registers fine with an AEOTEC setup, why does it not register with the Silicon Labs? What do I miss. I tried including is many times (I only exclude with the PC Configurator of SiliconLabs, since I also did not find a way to safely exclude in openHab).
below are the properties:
|zwave_beaming |true|
|zwave_class_basic |BASIC_TYPE_ROUTING_SLAVE|
|zwave_class_generic |GENERIC_TYPE_THERMOSTAT|
|zwave_class_specific |SPECIFIC_TYPE_SETPOINT_THERMOSTAT|
|zwave_frequent |false|
|zwave_listening |false|
|zwave_neighbours ||
|zwave_nodeid |2|
|zwave_routing |true|
|zwave_secure |false|
|zwave_version |0.0|
what am I missing?
thanks
Alexander
