ok. I did some testing with the latest binding and there is a different problem so I cannot recommed installing it. So we need to stick with the latest release build.
Let’s do it step by step (please do not omit some steps):
Make a backup of your config: run /usr/share/openhab/runtime/bin/backup
Delete all files you have added to /usr/share/openhab/addons (you can leave addons.kar and any other (non-shelly) binding you might have copied there earlier)
Delete Shelly things
Uninstall (“remove”) shelly binding from GUI in the Addons Store
open ssh connection to your openhab server and start openhab console
run bundle:list | grep Shelly and check whether all shelly bindings are uninstalled
bundle:list | grep Californium should return no hits
logout from oh console
stop openhab: sudo systemctl stop openhab
cleancache: sudo openhab-cli clean-cache
start openhab: sudo systemctl start openhab
wait a few minutes until openhab is fully started
start MainUI, goto Addons Store, add the Shelly binding, and click on the gear icon so that you can enter username and password for your shellys.
in MainUI, goto Settings → Things → Inbox
Your Shellys should automatically appear here
If not, goto Settings → Things → hit the plus button, select shelly binding and press “scan”
Your items will not get lost during this procedure. If you provide the same ThingUID when adding new things the chances are high that all items will be automatically re-linked to the things channel.
As i said the dev binding (which is the snapshot 4.2 binding) has a problem which you can check yourself: when trying to add things , the binding 4.3 does not appear in the list of bindings (at least here on my system).
This means we need to go back to 4.1.1
Sorry for the confusion
But now I can´t get back.
I have two shelly bindings with snapshot an none with 4.1.1
Is it possible to make a clean installation and restore the backup?
I assume your addon folder is empty?
Remove the binding of your screenshot
stop openhab and cleancache
restart your Pi
now install shelly binding. watch out that you do not install the binding from marketplace but the „regular“ one from „openhab Distribution“
My folder is empty.
There is only the kar - file in it.
There is are 2 Shelly Binding in the openHab distribution shown, but if I open them, there is the sampsot as version.
If I install one and click to the other one it opens and shows installed.
If I open both, I see the snapshot version.
The only Shelly1 is the garage opener.
So I’ll try to solve the problem with http binding and call the url.
