Shelly 1 setup with embedded MQTT broker
(Steve Janzen) #1
Ok I am a real newbie. I have bought some Shelly1s and work of couse great with the app. I have changed the to mqtt to use them with openhab. I am trying with the embedded MQTT broker but i am having no luck. I have tried everything that I have read but nothing seems to work. If anyone can help me I would really appreciate it. My wife is getting tired of me on the computer and swearing all of the time. :wink:
Thanks!!
(CM6.5 H102) #2
Are you using PaperUI or files for setting up MQTT?
(Steve Janzen) #3
Yes.
(CM6.5 H102) #4
Yes for files or PaperUI?
Here is a link showing a setup with shelly and using files.
(Steve Janzen) #5
Sorry I didi not read it all. I am trying to use PaperUI. I thought it would be easier for me.
(CM6.5 H102) #6
That’s the general consensus, but I’m hardheaded and prefer files.:laughing:
(Steve Janzen) #7
And I wanted to use the embedded MQTT broker
(CM6.5 H102) #8
Have you read this
(Steve Janzen) #9
Yes I did but I will go through it again. Maybe I will try with Mosquito as well. Thanks!!
(Jonatan Stridh) #10
Have you found a solution?
I’m also having trouble getting this to work. Since I’m new to MQTT I don’t really know where I’m failing. How can I check wich link in the chain that are broken?
I think I’ve setup my embedded broker alright, but I really have no clue :stuck_out_tongue:
I’m running OH 2.4 stable on a win 10 laptop.
(Steve Janzen) #11
No I not. I am going to redo my whole setup this time with raspberry pi. Let’s see if I can get it working.
