I managed to open and close the rollershutter via shelly binding in openHAB.
I’d like to display and control the position between 0 and 100% with a slider. How can I achieve this?
Thanks a lot for your help.
Did you try searching the forum?
https://community.openhab.org/search?q=Shelly%20rollershutter%20with%20slider
I did. Nothing found with bindings, just MQTT.
Thank you.
Did you find a solution (not through MQTT) ?
What is your Item type? Presumably you just add a slider to your Sitemap, linked to the Item?
If this doesn’t work, please post the problem with configurations.
