Tobus
(Tobus)
#1
Hello all,
sorry for that newbie question …
I have bought a Shelly 2 Dimmer, and want to control the brightness and read the temperature via OpenHab.
You can find the MQTT documentation of the Shelly here:
https://shelly-api-docs.shelly.cloud/#shelly-dimmer-sl-status
According to this, I can read the brightness via /light/0 with attribute brightness.
`GET /light/0
“ison”: false,
“has_timer”: false,
“timer_started”: 0,
“timer_duration”: 0,
“timer_remaining”: 0,
“mode”: “white”,
“brightness”: 50
MQTT State Topic is shellies/shellydimmer2-xx/light/0/ and this is not working, because the attribute is missing.
Where can I add these?
Thanks a lot
Tobias
Ensure the JSONPath Transformation service is installed, then use this for Incoming Value Transformations (assuming you’re using PaperUI)
JSONPATH:$.brightness
If you’re using files, add
transformationPattern="JSONPATH:$.brightness"
to your Thing Channel.
Tobus
(Tobus)
#3
Ahhh perfect you are right, the reporting is working now.
Last question, openHab shows me now the brightness as following:
14.14141414141414141414141414141414 %
What can i do to cut before the dot?
BR
Tobias
Tobus
(Tobus)
#5
This number represents the brightness. I configured at the shelly gui a brightness level of 15%, but at OpenHab it is represented as 14.141414%
How are you viewing this number in openHAB? PaperUI, BasicUI/sitemap, HABPanel?
Tobus
(Tobus)
#7
Primarily I’m usung HabPanel, but for debug options sometimes PaperUI
rossko57
(Rossko57)
#8
To control the presentation of Item values, use the [state presentation]
option embedded in the Item’s label definition.
"My dimmer text [%.0f %%]"
