is it possible to add a new channel for Shelly 1 to get the state of external sensor.
I’ve a temparatue-addon with a reed-switch to get my doorposition.
xxx.xxx.xxx.xxx/status: … “ext_switch”:{“0”:{“input”:0}} … close
xxx.xxx.xxx.xxx/status: … “ext_switch”:{“0”:{“input”:1}} … open
The MQTT server would basically receive messages from the Shelly which should include the information from the add-ons.
You will need to configure an MQTT server - I believe there is one in OpenHAB but from forum posts I would say it is better to install a separate MQTT server. You would then configure the Shelly to use that MQTT server and configure OpenHAB to subscribe to the server and relevant channels.
