- Platform information:
- Hardware:
Raspberry Pi 4 (4GB)
- OS:
OpenHabianPi
- Java Runtime Environment:
openjdk version “1.8.0_272”
OpenJDK Runtime Environment (Zulu 8.50.0.259-CA-linux_aarch32hf) (build 1.8.0_272-b17)
OpenJDK Client VM (Zulu 8.50.0.259-CA-linux_aarch32hf) (build 25.272-b17, mixed mode)
- openHAB version:
2.5.10
Issue of the topic:
Since yesterday, the Shelly Binding keeps pushing WARN messages in the Log, but just some time after a reboot. Directly after the reboot everthing looks just fine. -
Please post configurations (if applicable):
Thing:
Thing shelly:shellyht:58F9A9 "ShellyHT 58F9A9" @ "1G_Schlafzimmer" [ deviceIp="192.168.1.32", userId="admin", password="XXXX", lowBattery=15 , eventsCoIoT=true ] -
item:
Switch ShellyHT003_DeviceUpdateAvailable "Device update available" <settings> (1G_Schlafzimmer) {channel="shelly:shellyht:58F9A9:device#updateAvailable"} Number ShellyHT003_temperature "Temperatur" <temperature> (1G_Schlafzimmer) {channel="shelly:shellyht:58F9A9:sensors#temperature"} Number ShellyHT003_targetTemperature "Soll Temperatur" <temperature> (1G_Schlafzimmer) Number ShellyHT003_humidity "Luftfeuchtigkeit" <humidity> (1G_Schlafzimmer) {channel="shelly:shellyht:58F9A9:sensors#humidity"} Number ShellyHT003_charger "Ladegerät" <power> (1G_Schlafzimmer) {channel="shelly:shellyht:58F9A9:sensors#charger"} Number ShellyHT003_wifisignal "wifiSignal" <wifi> (1G_Schlafzimmer) {channel="shelly:shellyht:58F9A9:device#wifiSignal"} DateTime ShellyHT003_lastUpdate "Letztes Update" <time> (1G_Schlafzimmer) {channel="shelly:shellyht:58F9A9:sensors#lastUpdate"}
If logs where generated please post these here using code fences:
2020-12-11 12:04:46.402 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler ShellyRelayHandler of thing shelly:shellyht:957271 tried checking if channel sensors#humidity is linked although the handler was already disposed. 2020-12-11 12:04:46.403 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler ShellyRelayHandler of thing shelly:shellyht:957271 tried checking if channel sensors#temperature is linked although the handler was already disposed. 2020-12-11 12:04:46.404 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler ShellyRelayHandler of thing shelly:shellyht:957271 tried checking if channel battery#batteryLevel is linked although the handler was already disposed. 2020-12-11 12:04:46.406 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler ShellyRelayHandler of thing shelly:shellyht:957271 tried checking if channel sensors#humidity is linked although the handler was already disposed. 2020-12-11 12:04:46.407 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler ShellyRelayHandler of thing shelly:shellyht:957271 tried checking if channel battery#lowBattery is linked although the handler was already disposed. 2020-12-11 12:04:46.409 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler ShellyRelayHandler of thing shelly:shellyht:957271 tried checking if channel battery#batteryLevel is linked although the handler was already disposed. 2020-12-11 12:04:46.409 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler ShellyRelayHandler of thing shelly:shellyht:957271 tried checking if channel device#heartBeat is linked although the handler was already disposed. 2020-12-11 12:04:46.411 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler ShellyRelayHandler of thing shelly:shellyht:957271 tried checking if channel battery#lowBattery is linked although the handler was already disposed. 2020-12-11 12:04:46.414 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler ShellyRelayHandler of thing shelly:shellyht:957271 tried checking if channel device#heartBeat is linked although the handler was already disposed.
