Shelly binding probable problem - Thing not works correctly
hello
I have a frequent problem on shelly pro 2 pm.
Here the decription:
Sometime, the device connected to the selly (a tend) do not respond to openhab and alexa, connected to openhab.
I try to stop and restart the Thing via MainUI. But no success… Online the thing but not respond.
If i use the native app. It works correctly
Gemini suggest me to try via Curl command on the RPi 5 (the one with openhab installed on it) and works correctly
curl -X POST -d '{"id":1, "method":"Cover.GoToPosition", "params":{"id":0, "pos":20}}' http://192.168.178.126/rpc
{"id":1,"src":"shellyplus2pm-485519a26698","result":null}
It suggest that could be a Binding Issue.
Here is Log complete output
info_circle 17:36:35.222	INFO
openhab.event.ItemStateChangedEvent
Item 'Shelly_Tenda_Presenza_Latency' changed from 0.035777984 s to 0.006513471 s
info_circle 17:36:35.402	INFO
Item 'Shelly_Tenda_Presenza_Last_Seen' changed from 2025-09-17T17:35:35.213189516+0200 to 2025-09-17T17:36:35.401086955+0200
info_circle 17:36:51.719	INFO
Item 'ShellyDimmerCorridoioPresenza_Latency' changed from 0.046137496 s to 0.032599929 s
info_circle 17:36:51.891	INFO
Item 'ShellyDimmerCorridoioPresenza_LastSeen' changed from 2025-09-17T17:35:51.685209022+0200 to 2025-09-17T17:36:51.889166249+0200
info_circle 17:36:56.490	INFO
Item 'ShellyCancelloPresenza_Latency' changed from 0.022772489 s to 0.01127444 s
info_circle 17:36:56.707	INFO
Item 'ShellyCancelloPresenza_LastSeen' changed from 2025-09-17T17:35:56.477108569+0200 to 2025-09-17T17:36:56.705192300+0200
info_circle 17:37:35.408	INFO
Item 'Shelly_Tenda_Presenza_Latency' changed from 0.006513471 s to 0.004979006 s
info_circle 17:37:35.631	INFO
Item 'Shelly_Tenda_Presenza_Last_Seen' changed from 2025-09-17T17:36:35.401086955+0200 to 2025-09-17T17:37:35.629251047+0200
info_circle 17:37:51.930	INFO
Item 'ShellyDimmerCorridoioPresenza_Latency' changed from 0.032599929 s to 0.039457791 s
info_circle 17:37:52.106	INFO
Item 'ShellyDimmerCorridoioPresenza_LastSeen' changed from 2025-09-17T17:36:51.889166249+0200 to 2025-09-17T17:37:52.105106636+0200
info_circle 17:37:56.719	INFO
Item 'ShellyCancelloPresenza_Latency' changed from 0.01127444 s to 0.011151144 s
info_circle 17:37:56.902	INFO
Item 'ShellyCancelloPresenza_LastSeen' changed from 2025-09-17T17:36:56.705192300+0200 to 2025-09-17T17:37:56.901058221+0200
ant 17:38:24.796	DEBUG
org.openhab.binding.shelly.internal.api1.Shelly1CoapHandler
shellydimmer2-8caab5555b5d: CoIoT Message from /192.168.178.133:5683 (MID=9755): {"G":[[0,9103,0],[0,1101,0],[0,5101,17],[0,2101,0],[0,2102,""],[0,2103,0],[0,2201,0],[0,2202,""],[0,2203,0],[0,4101,0.00],[0,4103,0],[0,6102,0],[0,6109,0.00],[0,6104,0],[0,3104,41.09],[0,3105,105.96],[0,6101,0],[0,9101,"white"]]}
line_horizontal_3 17:38:24.797	TRACE
org.openhab.binding.shelly.internal.handler.ShellyBaseHandler
shellydimmer2-8caab5555b5d: Watchdog restarted (expires in 70 sec)
ant 17:38:24.797	DEBUG
shellydimmer2-8caab5555b5d: Serial -1 was already processed, ignore update
ant 17:38:26.128	DEBUG
shelly1-f4cfa2ecefa6: CoIoT Message from /192.168.178.127:5683 (MID=50715): {"G":[[0,9103,0],[0,1101,0],[0,2101,0],[0,2102,""],[0,2103,0]]}
line_horizontal_3 17:38:26.129	TRACE
shelly1-f4cfa2ecefa6: Watchdog restarted (expires in 70 sec)
ant 17:38:26.129	DEBUG
shelly1-f4cfa2ecefa6: Serial -1 was already processed, ignore update
line_horizontal_3 17:38:27.926	TRACE
org.openhab.binding.shelly.internal.api.ShellyHttpClient
shellyplus2pm-485519a26698: HTTP POST http://192.168.178.126/rpc Accept-Encoding: gzip User-Agent: Jetty/9.4.57.v20241219 Content-Type: application/json; charset=UTF-8 {"id":499037947,"src":"openhab-192.168.178.140","method":"Shelly.GetStatus"}
line_horizontal_3 17:38:27.974	TRACE
shellyplus2pm-485519a26698: HTTP Response 200: {"id":499037947,"src":"shellyplus2pm-485519a26698","dst":"openhab-192.168.178.140","result":{"ble":{},"cloud":{"connected":true},"cover:0":{"id":0, "source":"timeout", "state":"stopped","apower":0.0,"voltage":237.1,"current":0.000,"pf":0.00,"freq":50.0,"aenergy":{"total":1099.687,"by_minute":[0.000,0.000,946.936],"minute_ts":1758123480},"temperature":{"tC":55.1, "tF":131.2},"pos_control":true,"last_direction":"open","current_pos":60},"input:0":{"id":0,"state":false},"input:1":{"id":1,"state":false},"mqtt":{"connected":false},"sys":{"mac":"485519A26698","restart_required":false,"time":"17:38","unixtime":1758123507,"uptime":22428,"ram_size":245296,"ram_free":133628,"fs_size":458752,"fs_free":114688,"cfg_rev":24,"kvs_rev":0,"schedule_rev":1,"webhook_rev":0,"available_updates":{"beta":{"version":"1.7.1-beta1"},"stable":{"version":"1.7.0"}},"reset_reason":3},"wifi":{"sta_ip":"192.168.178.126","status":"got ip","ssid":"ZEDGEAR50","rssi":-54},"ws":{"connected":false}}} Content-Type: application/json Content-Length: 976 Server: ShellyHTTP/1.0.0 Connection: close
line_horizontal_3 17:38:27.975	TRACE
org.openhab.binding.shelly.internal.api2.Shelly2ApiClient
shellyplus2pm-485519a26698: API value 'stopped' was mapped to 'stop'
ant 17:38:27.975	DEBUG
shellyplus2pm-485519a26698: Roller status changed from stop to stop, updateChannels=false
line_horizontal_3 17:38:27.976	TRACE
shellyplus2pm-485519a26698: Watchdog restarted (expires in 70 sec)
org.openhab.binding.shelly.internal.handler.ShellyRelayHandler
shellyplus2pm-485519a26698: Updating 1 rollers
ant 17:38:27.976	DEBUG
shellyplus2pm-485519a26698: Update roller position to 60/40, state=stop
info_circle 17:38:35.642	INFO
Item 'Shelly_Tenda_Presenza_Latency' changed from 0.004979006 s to 0.009504624 s
info_circle 17:38:35.835	INFO
Item 'Shelly_Tenda_Presenza_Last_Seen' changed from 2025-09-17T17:37:35.629251047+0200 to 2025-09-17T17:38:35.833548938+0200
ant 17:38:39.753	DEBUG
shellydimmer2-8caab5555b5d: CoIoT Message from /192.168.178.133:5683 (MID=9756): {"G":[[0,9103,0],[0,1101,0],[0,5101,17],[0,2101,0],[0,2102,""],[0,2103,0],[0,2201,0],[0,2202,""],[0,2203,0],[0,4101,0.00],[0,4103,0],[0,6102,0],[0,6109,0.00],[0,6104,0],[0,3104,41.09],[0,3105,105.96],[0,6101,0],[0,9101,"white"]]}
line_horizontal_3 17:38:39.753	TRACE
line_horizontal_3 17:38:41.011	TRACE
shellydimmer2-8caab5555b5d: HTTP GET http://192.168.178.133/status Accept-Encoding: gzip User-Agent: Jetty/9.4.57.v20241219 Content-Type: application/x-www-form-urlencoded
line_horizontal_3 17:38:41.126	TRACE
shellydimmer2-8caab5555b5d: HTTP Response 200: {"wifi_sta":{"connected":true,"ssid":"ZEDGEAR50","ip":"192.168.178.133","rssi":-59},"cloud":{"enabled":true,"connected":true},"mqtt":{"connected":false},"time":"17:38","unixtime":1758123521,"serial":22,"has_update":false,"mac":"8CAAB5555B5D","cfg_changed_cnt":0,"actions_stats":{"skipped":0},"lights":[{"ison":false,"source":"input","has_timer":false,"timer_started":0,"timer_duration":0,"timer_remaining":0,"mode":"white","brightness":17,"transition":0}],"meters":[{"power":0.00,"overpower":0.00,"is_valid":true, "timestamp":1758130721,"counters":[0.000, 0.000, 0.000],"total":0}],"inputs":[{"input":0,"event":"","event_cnt":0},{"input":0,"event":"","event_cnt":0}],"tmp":{"tC":41.02,"tF":105.83, "is_valid":true},"calibrated":true,"calib_progress":0,"calib_status":0,"calib_running":0,"wire_mode":1,"forced_neutral":false,"overtemperature":false,"loaderror":0,"overpower":false,"debug":0,"update":{"status":"idle","has_update":false,"new_version":"20230913-114008/v1.14.0-gcb84623","old_version":"20230913-114008/v1.14.0-gcb84623","beta_version":"20231107-164738/v1.14.1-rc1-g0617c15"},"ram_total":49672,"ram_free":37372,"fs_size":233681,"fs_free":118472,"uptime":960} Server: Mongoose/6.18 Connection: close Content-Type: application/json Content-Length: 1170
line_horizontal_3 17:38:41.127	TRACE
ant 17:38:41.390	DEBUG
shelly1-f4cfa2ecefa6: CoIoT Message from /192.168.178.127:5683 (MID=50716): {"G":[[0,9103,0],[0,1101,0],[0,2101,0],[0,2102,""],[0,2103,0]]}
line_horizontal_3 17:38:41.391	TRACE
ant 17:38:41.391	DEBUG
info_circle 17:38:47.984	INFO
openhab.event.ItemCommandEvent
Item 'Shelly_Tenda_Roller_Control_0open_100closed' received command STOP
info_circle 17:38:48.671	INFO
Item 'Shelly_Tenda_Roller_Control_0open_100closed' received command UP
info_circle 17:38:48.672	INFO
openhab.event.ItemStatePredictedEvent
Item 'Shelly_Tenda_Roller_Control_0open_100closed' predicted to become UP
info_circle 17:38:48.673	INFO
Item 'Shelly_Tenda_Roller_Control_0open_100closed' changed from 100 to 0
info_circle 17:38:52.114	INFO
Item 'ShellyDimmerCorridoioPresenza_Latency' changed from 0.039457791 s to 0.00672975 s
info_circle 17:38:52.314	INFO
Item 'ShellyDimmerCorridoioPresenza_LastSeen' changed from 2025-09-17T17:37:52.105106636+0200 to 2025-09-17T17:38:52.313118437+0200
ant 17:38:53.272	DEBUG
shellydimmer2-8caab5555b5d: CoIoT Message from /192.168.178.133:5683 (MID=9757): {"G":[[0,9103,0],[0,1101,0],[0,5101,17],[0,2101,0],[0,2102,""],[0,2103,0],[0,2201,0],[0,2202,""],[0,2203,0],[0,4101,0.00],[0,4103,0],[0,6102,0],[0,6109,0.00],[0,6104,0],[0,3104,41.57],[0,3105,106.83],[0,6101,0],[0,9101,"white"]]}
line_horizontal_3 17:38:53.272	TRACE
shellydimmer2-8caab5555b5d: CoIoT Sensor data {"G":[[0,9103,0],[0,1101,0],[0,5101,17],[0,2101,0],[0,2102,""],[0,2103,0],[0,2201,0],[0,2202,""],[0,2203,0],[0,4101,0.00],[0,4103,0],[0,6102,0],[0,6109,0.00],[0,6104,0],[0,3104,41.57],[0,3105,106.83],[0,6101,0],[0,9101,"white"]]} (serial=-1)
ant 17:38:53.273	DEBUG
shellydimmer2-8caab5555b5d: 18 CoAP sensor updates received
line_horizontal_3 17:38:53.273	TRACE
shellydimmer2-8caab5555b5d: Sensor value[0]: id=9103, Value=0.0 (cfgChanged, Type=EVC, Range=U16, Link=4: device)
shellydimmer2-8caab5555b5d: Sensor value[1]: id=1101, Value=0.0 (output, Type=S, Range=0/1, Link=1: light_0)
shellydimmer2-8caab5555b5d: Sensor value[2]: id=5101, Value=17.0 (brightness, Type=S, Range=1/100, Link=1: light_0)
shellydimmer2-8caab5555b5d: Sensor value[3]: id=2101, Value=0.0 (input, Type=S, Range=0/1, Link=2: input_0)
shellydimmer2-8caab5555b5d: Sensor value[4]: id=2102, Value=-1.0 (inputEvent, Type=EV, Range=S/L;, Link=2: input_0)
shellydimmer2-8caab5555b5d: Sensor value[5]: id=2103, Value=0.0 (inputEventCnt, Type=EVC, Range=U16, Link=2: input_0)
org.openhab.binding.shelly.internal.api1.Shelly1CoIoTProtocol
Shelly Dimmer Corridoio: Check button[0] for event trigger (inButtonMode=false, isButton=false, hasBattery=false, serial=-1, count=0, lastEventCount[0]=0
line_horizontal_3 17:38:53.274	TRACE
shellydimmer2-8caab5555b5d: Sensor value[6]: id=2201, Value=0.0 (input, Type=S, Range=0/1, Link=3: input_1)
shellydimmer2-8caab5555b5d: Sensor value[7]: id=2202, Value=-1.0 (inputEvent, Type=EV, Range=S/L;, Link=3: input_1)
shellydimmer2-8caab5555b5d: Sensor value[8]: id=2203, Value=0.0 (inputEventCnt, Type=EVC, Range=U16, Link=3: input_1)
Shelly Dimmer Corridoio: Check button[1] for event trigger (inButtonMode=false, isButton=false, hasBattery=false, serial=-1, count=0, lastEventCount[1]=0
shellydimmer2-8caab5555b5d: Sensor value[9]: id=4101, Value=0.0 (power, Type=P, Range=0/230;-1, Link=1: light_0)
shellydimmer2-8caab5555b5d: Sensor value[10]: id=4103, Value=0.0 (energy, Type=E, Range=U32;-1, Link=1: light_0)
shellydimmer2-8caab5555b5d: Sensor value[11]: id=6102, Value=0.0 (overpower, Type=A, Range=0/1;-1, Link=1: light_0)
shellydimmer2-8caab5555b5d: Sensor value[12]: id=6109, Value=0.0 (overpowerValue, Type=P, Range=U32;-1, Link=1: light_0)
shellydimmer2-8caab5555b5d: Sensor value[13]: id=6104, Value=0.0 (loadError, Type=A, Range=0/1, Link=1: light_0)
shellydimmer2-8caab5555b5d: Sensor value[14]: id=3104, Value=41.57 (deviceTemp, Type=T, Range=-40/300;999, Link=4: device)
shellydimmer2-8caab5555b5d: Sensor value[15]: id=3105, Value=106.83 (deviceTemp, Type=T, Range=-40/572;999, Link=4: device)
line_horizontal_3 17:38:53.275	TRACE
shellydimmer2-8caab5555b5d: Sensor value[16]: id=6101, Value=0.0 (overtemp, Type=A, Range=0/1;-1, Link=4: device)
shellydimmer2-8caab5555b5d: Sensor value[17]: id=9101, Value=white (mode, Type=S, Range=color/white, Link=4: device)
ant 17:38:53.275	DEBUG
shellydimmer2-8caab5555b5d: 2 channels updated from CoIoT status, serial=-1
line_horizontal_3 17:38:56.129	TRACE
line_horizontal_3 17:38:56.274	TRACE
shellydimmer2-8caab5555b5d: HTTP Response 200: {"wifi_sta":{"connected":true,"ssid":"ZEDGEAR50","ip":"192.168.178.133","rssi":-59},"cloud":{"enabled":true,"connected":true},"mqtt":{"connected":false},"time":"17:38","unixtime":1758123536,"serial":23,"has_update":false,"mac":"8CAAB5555B5D","cfg_changed_cnt":0,"actions_stats":{"skipped":0},"lights":[{"ison":false,"source":"input","has_timer":false,"timer_started":0,"timer_duration":0,"timer_remaining":0,"mode":"white","brightness":17,"transition":0}],"meters":[{"power":0.00,"overpower":0.00,"is_valid":true, "timestamp":1758130736,"counters":[0.000, 0.000, 0.000],"total":0}],"inputs":[{"input":0,"event":"","event_cnt":0},{"input":0,"event":"","event_cnt":0}],"tmp":{"tC":41.02,"tF":105.83, "is_valid":true},"calibrated":true,"calib_progress":0,"calib_status":0,"calib_running":0,"wire_mode":1,"forced_neutral":false,"overtemperature":false,"loaderror":0,"overpower":false,"debug":0,"update":{"status":"idle","has_update":false,"new_version":"20230913-114008/v1.14.0-gcb84623","old_version":"20230913-114008/v1.14.0-gcb84623","beta_version":"20231107-164738/v1.14.1-rc1-g0617c15"},"ram_total":49672,"ram_free":37372,"fs_size":233681,"fs_free":118472,"uptime":976} Server: Mongoose/6.18 Connection: close Content-Type: application/json Content-Length: 1170
line_horizontal_3 17:38:56.277	TRACE
shellydimmer2-8caab5555b5d: 0 more updates requested
ant 17:38:56.540	DEBUG
shelly1-f4cfa2ecefa6: CoIoT Message from /192.168.178.127:5683 (MID=50717): {"G":[[0,9103,0],[0,1101,0],[0,2101,0],[0,2102,""],[0,2103,0]]}
line_horizontal_3 17:38:56.541	TRACE
ant 17:38:56.541	DEBUG
Can some expert try to understand what is happening ?
I can give you the data if needed.
Thank you,
Muplex
